Help with vegetation?
Posted: Tue Dec 23, 2014 2:11 am
by kkullar
Hey Guys,
I have a scene which im working and have ran into some problems,
First of all a brief description of the scene is, two high poly cars which have been modelled and rigged and an environment which a sort of looks like country lane,
I was wondering what is the best way to do the vegetation for octane? The resources I have available are;
-paint effects because im a maya user
-onyxtree suite
I'm willing to look into new plug ins if they will do the job and octane renders the cars beautifully so if I can get a good render with the vegetation I will defiantly buy the full version right away.
I am aiming for a look like the scene in the gallery of this website with the Mazada but I'm aware that's done in MAx.
Thanks any help would be greatly appreciated.
Re: Help with vegetation?
Posted: Tue Dec 23, 2014 6:27 am
by glimpse
Hi there =)
First of all I'm not maya user so I'm going to speak more general (Standalone) &. A bit trom max perspective =)
If You want to get instances in 3ds max & scatter them I'd use Forest Pro by itoo. Carbon scatter, multi scatter works too & I read Guys even using corona? (Though I don't understand how, maybe it has some module for scaterring..)
Anyway, if You're Maya users, I'd simply export scene, open it in standalone & then use something like Phantom Scatter =) there's a huge theea by Guus (creator) on this forum (called phantom scatter) You can generate .csv file with it & usi it to place whatever meshes You like =) grass, trees, gravel, obsticles on air, whatever..- try it, it's really good! =)
Posted: Tue Dec 23, 2014 1:18 pm
by heartlessphil
I've tried Itoo Forest Pack and it works well, like Tom said. @OP You can always test the free version, forest pack lite, to see if you like it! Good luck!
Posted: Wed Dec 24, 2014 1:24 am
by kkullar
Thanks guys,
I'll look into these ideas,
I'm so Maya oriented so would like to stick in there but if needs be I would give the standalone a shot, could it be possible to export the scene to MAX use forest pack then export it back?
Then after that find some way to instance inside maya?
