Error in LiveDB - 'MSG:loop'
Posted: Fri Dec 05, 2014 2:45 am
by OOO
Hey there
When clicking on all directories with subdirectories and some subdirectories (not all), all I can see is 'MSG:loop' and no materials, any suggestions? I'm using Win7 x64/R16/2.06.
Re: Error in LiveDB - 'MSG:loop'
Posted: Fri Dec 05, 2014 3:08 am
by aoktar
update your version. thanks
Posted: Fri Dec 05, 2014 4:04 am
by OOO
I've installed the 2.14 plugin/stand alone, but the issue is still present.
Posted: Fri Dec 05, 2014 4:41 am
by OOO
Also, just to hijack my own thread with another question rather than start a new one... the 'Lock resolution' button doesn't seem to stick (in 2.06 or 2.14) when sending/restarting a render (see attached video). This isn't the correct functionality, right?
Thanks for the help.
Posted: Fri Dec 05, 2014 4:51 pm
by aoktar
we don't expect this lock behaviour. It should be sticked as you click. What operation will cause this "msg loop"? I can't see this
Posted: Sat Dec 06, 2014 6:09 am
by Stephano_22
I get the same MSG:Loop error when I access multiple categories for example
Otoy/sign,vent
Texture/plastic
I just assumed it meant there were no textures in that category. I too am using Win7 x64/R16/2.06.
I am still using the last stable version 2.06. Interesting that OP is stating the same issue after upgrading. On that note is there a thread that can direct me on how to upgrade (mainly about deleting current version and if I need to deactivate license then reactivate in new version?)
Steve
Posted: Sat Dec 06, 2014 1:15 pm
by aoktar
Hi guys,
i have checked this. But some caterigories are really empty. So there is no problem about livedb. You can/should use the standalone for sometimes to check issues. It's same on standalone.
Upgrade is really straight. Just download zip file from topics and remove old files and copy new one. No need to reactivate.
Posted: Sat Dec 06, 2014 6:13 pm
by Stephano_22
Cool...thanks for the info !
Posted: Mon Dec 08, 2014 12:57 pm
by OOO
Ah yeah, it is just in the directories that are blank in the standalone, thanks aoktar.
If I can give any more info about the locking resolution issue let me know - I tried in R15 with 2.06 and it has the same issue for me.
