Page 1 of 2
Camera ?
Posted: Sun Nov 14, 2010 7:00 pm
by Buckaroo
plugin v.122d..not same camera ,octane and softimage render?
i want to matte render with xsi..
Re: Camera ?
Posted: Sun Nov 14, 2010 7:43 pm
by Carl S.
Here is the result which may get you more help considering it takes the step of putting it together to see the problem away.
Re: Camera ?
Posted: Sun Nov 14, 2010 8:10 pm
by face
In Octane, a pixel is a square, so that a pixel ratio of 0.9 doesn´t work correct.
Use a pixel ratio of 1 in the render options and copy the aspect ratio from the render options to the camera picture ratio.
A other thing is, that the result not 100% match between Octane and Softimage/Maya/Max, maybe 99%...
face
Re: Camera ?
Posted: Sun Nov 14, 2010 8:25 pm
by Buckaroo
:D it's work, thank you face..
why result not 100%?
Re: Camera ?
Posted: Sun Nov 14, 2010 8:30 pm
by face
I don´t know, its a Octane issue and it´s precental.
If you image has 720x576 the rendered result is maybe a half pixel moved to lower left or so.
I don´t know it precise it´s long ago ;)
But the greater the image the greater the movement.
face
Re: Camera ?
Posted: Fri Feb 11, 2011 8:13 am
by Alul
Hello. I have some other problem. When I export frame, camera "roll" when i look upward. Problem is visible only when i use this kind of frog perspective shot. here are examples:
http://img829.imageshack.us/g/camerarol ... ctane.png/
Am I doing something wrong?
Re: Camera ?
Posted: Fri Feb 11, 2011 1:42 pm
by face
Can you make a little Softimage scene and add it as zip?
face
Re: Camera ?
Posted: Sat Feb 12, 2011 1:28 pm
by Alul
Re: Camera ?
Posted: Fri Feb 25, 2011 10:38 am
by Alul
Hi, Just want to ask if you looked at it already?
I`m quite sure that I doing something wrong :)
Re: Camera ?
Posted: Fri Feb 25, 2011 2:57 pm
by face
Hm, i thought I has answer to this :oops:
Has you posted it also on an other thread?
The result from Octane and Softimage looks the same for me.
face
