Looking for tips on projecting caustic light patterns
Posted: Fri Oct 31, 2014 12:20 am
by bloopatone
Looking for any tutorials or tips for projecting caustic light patterns on a model of the sea floor. Trying to create a very generic underwater environment.
Eric Keller
Re: Looking for tips on projecting caustic light patterns
Posted: Fri Oct 31, 2014 2:13 am
by FooZe
You will need a water surface (obviously!) then set it as a specular material.
Use the PMC kernel (make sure your caustic blur is not too high). Also using the daylight (rather than texture) environment is a must (or some other powerful small emitter so that it gets "focused" buy the water surface.)
Posted: Fri Oct 31, 2014 9:38 am
by smicha
Fooze,
BTW: Does sun size and turbidity matter for caustics?
Posted: Mon Nov 03, 2014 12:00 am
by FooZe
Yes, any changes to the lighting will change the look of the caustics, including sun size and turbidity.
Posted: Mon Nov 03, 2014 6:47 pm
by bloopatone
Thanks for the reply!
Is there's no way to simply project a texture through a light source as in a Gobo?
Posted: Mon Nov 03, 2014 7:41 pm
by bloopatone
Your suggestions work great BTW, thanks very much!
