Page 1 of 2
X-particles
Posted: Sat Oct 25, 2014 6:30 pm
by simonun
I'm trying to run some tests with x particles and wanted to check if you guys have some suggestions. I couldn't find anything on the forum. Here I'm working with normal emitter (white spheres) and a skinner.
Do you guys know for example how to get rid of the white spheres or change them somehow? I couldnt figure it out.
Re: X-particles
Posted: Sat Oct 25, 2014 7:30 pm
by zackyd
you change the size in the emitter section. To turn them off look in the drop down options in the dialog menu
Re: X-particles
Posted: Sat Oct 25, 2014 9:18 pm
by aoktar
hi, looks great. All joking aside, disable Octane dialog->options->enable particle engine.
This causes to produce a sphere for each particles
Re: X-particles
Posted: Sat Oct 25, 2014 9:31 pm
by simonun
thanks, if I change the radius in the emitter it doesn't really change the size of the particle rendered.
Where should I change it?
Re: X-particles
Posted: Sat Oct 25, 2014 9:33 pm
by aoktar
it refers to radius of particles
Re: X-particles
Posted: Sun Oct 26, 2014 5:25 pm
by simonun
okay it worked now, you have to restart the animation.
Good stuff, thanks!
Re: X-particles
Posted: Fri Oct 31, 2014 2:48 am
by Gwrath
I am testing the demo version of x-particles and can't get them to generate in octane. If I use the cinema 4D particles i can see them (only as a white sphere when I enable the particle engine). How do I make it so I can see the x-particles in Octane and give them a different material/size?
if someone can make a quick test scene that would be awesome. Or any other info.
Just not sure what I'm missing here.
Re: X-particles
Posted: Fri Oct 31, 2014 9:26 am
by aoktar
Demo xp doesn't give particle data, that's the problem
Re: X-particles
Posted: Sat Nov 01, 2014 2:31 am
by Gwrath
Ah, Thought it may be something like that. Thanks for the quick reply.
Re: X-particles
Posted: Sat Nov 01, 2014 2:32 am
by Gwrath
Is there a way to scale the native cinema 4D particles while using the octane particle engine. I can get them to show up, but can't give them a color or different scale. Do you have to use the hair material or something?
