DL-AO and Glass
Posted: Thu Oct 16, 2014 6:56 pm
by Lewis
Hi!
Is it possible to render DL with Ambient Occlusion mode and still get windows reflection form inside of room? I'm rendering interior shoot and i need fast animation so i can't "afford" to wait for PathTracing verison to be done so I'd like to give it a try with AO but windows/glass (I have fake shadows ON) look kinda bad
Thanks for help
Re: DL-AO and Glass
Posted: Thu Oct 16, 2014 7:18 pm
by Seekerfinder
Hi Lewis,
I presume you're using a specular material for the glass? Have you tried using a glossy material with opacity at 90%? A light grey material usually works for me. Play with the reflection values until you get a desirable result.
Hope this helps.
Best,
Seeker
Re: DL-AO and Glass
Posted: Thu Oct 16, 2014 8:27 pm
by kavorka
Have you tried the glass fake falloff material on the liveDB?
Re: DL-AO and Glass
Posted: Thu Oct 16, 2014 8:35 pm
by Lewis
Thanks for info guys. I'll try that suggestion SeekerFinder.
As for Live DB material, sorry i should mention I'm using it inside LW+plugin and we don't have LiveDB suppor tin LW (yet).
Re: DL-AO and Glass
Posted: Fri Oct 17, 2014 11:54 am
by kavorka
Lewis wrote:Thanks for info guys. I'll try that suggestion SeekerFinder.
Well the material uses a glossy material with a falloff node plugged into the opacity. Gives a nice glass material and renders faster than real glass.
Re: DL-AO and Glass
Posted: Fri Oct 17, 2014 12:23 pm
by juanjgon
For simple materials you can always download it in Standalone and copy the node tree in LW ... the nodes and parameters are the same
Re: DL-AO and Glass
Posted: Fri Oct 17, 2014 12:43 pm
by Lewis
juanjgon wrote:Lewis wrote:Thanks for info guys. I'll try that suggestion SeekerFinder.
Sure I could if i had time and knowledge how to use standalone
