Rhino Network rendering problem
Posted: Thu Oct 02, 2014 2:08 pm
by splittmatt
I have a situation where I can see my colleagues network Daemon in both the standalone and MAX versions of Octane but not in Rhino?
If I have Rhino running at the same time I lose the connections in both Standalone and MAX, as if Rhino blocks the network connection.
I have ver 2.06 installed in all situations.
To make it even stranger my colleague can see my network Daemon and doesn't have the Rhino problem even though we have the exact same software.
Any ideas? Thanks.
Re: Rhino Network rendering problem
Posted: Thu Oct 02, 2014 10:02 pm
by face_off
My understanding is that once you open the network render settings on Standalone, the plugin will not see the slaves. So shutdown Standalone and Max first. I believe there is some work being done in this area to address this.
Posted: Fri Oct 03, 2014 11:47 am
by splittmatt
Hi Paul.
Unfortunately Rhino won't see the other daemon even without max or the standalone running. It may be a firewall issue between the two computers? Strange though that the other computer can see my daemon but I can't see it.
Matt
Posted: Fri Oct 03, 2014 10:46 pm
by face_off
I will ask FooZe to assist you further.
Posted: Sun Oct 05, 2014 11:10 pm
by FooZe
splittmatt wrote:Hi Paul.
Matt
I would suggest turning off the windows firewall just to test to see if it is a firewall issue (and any other firewalls you may have).
