C4D Background object
Posted: Fri Sep 26, 2014 6:30 am
by tomabobu
I'm using a background object with a C4D material that has a picture on the colour channel and when I'm changing the "Render Buffer Type" from 8 bit to float, the background in no longer visible.
What can I do to fix this?
Re: C4D Background object
Posted: Fri Sep 26, 2014 12:42 pm
by aoktar
Floatbuffer does not yet supports this feature. You should mix it in external software
Posted: Fri Sep 26, 2014 12:51 pm
by tomabobu
Thank you for the answer.
Is there a way I can use a ground surface as a matte to hold the reflection of the other objects in the scene? (other than in compositing)
I know that you can check the "Matte" attribute for diffuse materials, but this type of material doesn't has reflection and I would like to get that also.
Posted: Fri Sep 26, 2014 12:57 pm
by aoktar
tomabobu wrote:Thank you for the answer.
Hi, would the reflection pass help to you?
Posted: Fri Sep 26, 2014 4:52 pm
by tomabobu
The reflection pass is great in compositing, but I was wondering if this is possible to get straight from the renderer.
