Page 1 of 3
hdri vs whitout
Posted: Fri Feb 05, 2010 8:19 am
by Daniel79
This render i try to use an hdri image but the noise istoo much..
The same render whitout hdri in onli few second is clean..
Where i wrong??
There are a setting wrong about pathtracing option??
Please help me to obtain a clean image..please!!!
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 10:34 am
by Daniel79
ther's not anyone can help me? :cry:
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 10:40 am
by Sam
HDRI goes like this
The more blurry it is the less artefacts you get ;)
Try that, open the HDR file in Photoshop, do a small gaussian blur, save the HDR with the hdrname_blurred.hdr
Reload the blurred HDR in Octane, try to render and compare the two renders.
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 11:21 am
by Daniel79
I don't understand very well..
The noise due to hdri?
If i do a small gaussian blur in final image i have a clean image?
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 11:44 am
by radiance
The higher amount of noise is due to bright areas on the HDRI map.
A small amount of reflected rays find these bright spots,
giving more variance/bright contributions.
The solution is to let it render a little bit longer.
I need to develop more advanced algorithms in the near future that make situations like this less noisy.
Radiance
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 11:49 am
by Daniel79
thanks to all
i try to do what you say me..
I forgot to say i used demo v0.7
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 1:54 pm
by samartin
If you can, try and apply a Gaussian filter the HDR map you want to use. This should theoretically smooth out those problem spots!
This is a trick I used to use in LW, processing options which meant I didn't have to destroy or make a new HDR :)
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 4:18 pm
by Stereomike
@Radiance: Would be neat to have an option to blur and to edit the hdr-range (clip) of the background image inside of octane. This will help tweaking rendertimes.
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 4:23 pm
by radiance
i could add a button to clip it, but clip where ? :)
it depends on the average intensity i guess...
i'll think about it.
EDIT: one thing to remember is that when MLT is available all these issues are suddenly less important.
Radiance
Re: hdri vs whitout
Posted: Fri Feb 05, 2010 5:31 pm
by samartin
I quickly knocked up a preview showing a normal HDR image vs Gaussian HDR image.
Having controls would be great, but I'm sure you have tonnes on as it is...
