Shader Suggestions
Posted: Thu Sep 04, 2014 4:37 pm
Th there deer Octane Team,
First of all thanks for your hard work on Octane. I really like it and its quality is really outstanding!
I am a artist really focused on shading and I hereby wanted to give a couple of suggestions for shader implementation that came into my mind for eventual further releases of octane:
A fresnel Shader:
A shader that is like the Falloff Shader in behaviour only it gives out a Fresnel curve.
You should be able to tweak the Index / Nd value of course.
Reason:
Fresnel is a really important part of shading. You already have implemented it with the "Index" you can adjust to control the reflection amount in the "Glossy" material model and the refraction amount in the "Specular" material model.
If you want to do a car paint material you would use a blend material to blend materials together with 2 different reflection roughness levels.
The amount they are blended together is provided by the Fresnel normally.
Lacking a Fresnel shader you have to tweak the falloff the way it comes close to an Fresnel and use it in the mix amount slot. But this way you never can mace sure you have nailed down the Falloff to a physical correct amount. A Fresnel shader would make this much more simple by letting you just put in the right index and therefore producing a photo real result by itself.
Additional:
Integration of a Complex Fresnel (with a Extinction Coefficient)
Reason:
As you might now the Fresnel model implemented in most 3D applications is called "real part of complex index of refraction" and is driven with the Index Number / IOR / Nd derived from a materials meassured index at a light wavelength of 0.5893 μm.
This model is however only intended for non metal materials (as plastic glass etc)
To calculate the view depended reflection curve for metals you would need to add a extinction coefficient "K" (which is the imaginary part of the Fresnel formula)to the Index value. They both then dive the function and you will be able to calculate physically accurate metal reflections.
P.s. the only renderer I know of that has this implemented at the time is Maxwell.
GGX Distribution Functions
Recently Vray (in the 3.0 Built) and C4D R16 both have implemented the GGX "shader" to allow more flexibility with shading.
I´d really love to see this implemented in Octane as well! https://vimeo.com/88605345
Reason:
Different types of material have different distribution behaviours of reflections. To get even more realistic Reflection behavior this will further enhance the palette of what you can do with octane.
In my opinion this would improve Octanes feature set further and give even more flexibility in to the hand of the artists!
Thanks for reading and considering!
Cheers,
Raphael
A fresnel Shader:
Reason:
Additional:
Reason:
Reason:
Cheers,
Raphael
