Questions
Posted: Fri Aug 29, 2014 4:21 pm
by Redprophet
Congratulation on the beta release. I just have a couple of questions. Do you have plans for a demo version? Will hair be supported at some point?
Re: Questions
Posted: Sat Aug 30, 2014 12:20 am
by Sighman
Yes there will be a demo version soon.
No hair will not be supported in the near future. The Carrara hair module in incompatable with octane. I would need the source code for the hair module from DAZ to implement this feature.
Re: Questions
Posted: Sun Aug 31, 2014 9:08 am
by swordkensia
Hi Sighman,
Great Release. One very pleased customer..
As this is a questions thread, I wonder if I might hi-jack it and potentially turn it into a questions / feature request thread.??
I would like to ask. Would it be possible to incorporate Carrara's batch render feature into a future release of the Plugin..?? This would be a huge time saver for me as I could stack a load of images for rendering whilst I am at work..
Once again well done.!!!
Cheers,
S.K.
Re: Questions
Posted: Sun Aug 31, 2014 9:12 am
by swordkensia
Ah, another Question..
Are Normal Maps currently supported.??, and if they are how does one get them to work.
I plugged one into the Carrara bump channel(changed to normal,) but the mapping did not take effect.
Cheers,
S.K.
Re: Questions
Posted: Sun Aug 31, 2014 3:30 pm
by Sighman
Re Batch Rendering
Unfortunately, that feature won't be implemented any time soon. I'll add it to the list but the problem is that batch rendering is a feature of the render room and the Octane Plugin has nothing to do with the render room (except for reading a couple of settings). Maybe it could be done if the API can access the batch list, or I could implement my own batch list in the ORVP.
Re Normal Maps
My bad. I missed that one. I will fix it ASAP.
EDIT: You can work around this by converting the shader to an Octane Material and setting the normal map in the material node.
Re: Questions
Posted: Mon Sep 01, 2014 10:22 pm
by swordkensia
Sighman wrote:Re Batch Rendering
Re Normal Maps
Thank you Sighman for the quick reply..
Cheers,
S.K.
Re: Questions - Lighting
Posted: Fri Sep 05, 2014 10:07 am
by reality-1
I've successfully created a mesh light, and wanted to make sure I'm not missing something.
Are any Carrara lights supported somehow?
Or is there maybe a separate way to do spotlights in Octane?
Really pleased with the Plug-In so far, a couple crashes but only after "an error has occured" in Carrara. Gotta love Carrara in spite of its bugs!
Thanks again for extending it with Octane integration.
-John
Re: Questions
Posted: Fri Sep 05, 2014 10:18 am
by orion_uk
Hi Reality-1, Welcome aboard
Regarding lights, Myself and PhilW cover them a little here if you would like to take a look.
http://www.daz3d.com/forums/viewthread/ ... 90/#669979
I would go in to it more but am just heading out the door. I am sure you will get the idea but I am also sure people here will be happy to help you with anything you need help on
If I see you have had no replies then I will post later but I doubt you will go unheard
Carrara lights are not supported by this plugin but, if you take a look at the above link myself & PhilW have given a few tips on lighting (PhilW covers spot lights) so I am sure that will clear up a few things for you
Re: Questions
Posted: Sat Sep 06, 2014 7:38 am
by reality-1
I use spots quite a bit in Carrara, but not sure how many I'll need to use with the OR.
Emissions seem quite a bit different than anything glows, perhaps a bit more realistic.
Also looks like building a spot is pretty simple if it comes to that.
Thanks for the info!
orion_uk wrote:Hi Reality-1, Welcome aboard
