Page 1 of 2
Picture Viewer doesn't match Live Viewer
Posted: Sat Aug 23, 2014 6:35 pm
by mrbrown
Hello there,
I'm trying to render this spline animation and everything looks great on live viewer but when I try to do the final render I don't get the same shading resoult.
Scene file attached.
What am I doing wrong?
Thank you for your help.
Marco
Re: Picture Viewer doesn't match Live Viewer
Posted: Sat Aug 23, 2014 6:39 pm
by aoktar
When you are enabled multipass, C4D changes color profile of output. So you should use floatbuffer(tonemapped) in Octane Render settings
Posted: Sat Aug 23, 2014 6:45 pm
by mrbrown
Hi Aoktar, thank you for your fast answer.
like this? It doesn't look like it helps..
Posted: Sat Aug 23, 2014 7:17 pm
by aoktar
you should see correct colors when you open the saved images in after effects, etc.
Posted: Sat Aug 23, 2014 7:33 pm
by mrbrown
Unfortunately I don't, Photoshop and AE open the saved imaged just like i see it in the picture viewer.
Anything else you can think of?
Thank you again for your time and help.
Marco
Posted: Sat Aug 23, 2014 7:59 pm
by aoktar
problem could be related with 2.02. I have tweaked colour behaviour on some recent version. 2.05 is best. I remember that we tested colors for every workflow. it should works as I mentioned. I'm away from pc to test it
Posted: Sat Aug 23, 2014 8:46 pm
by mrbrown
Updated to latest standalone and c4d plugin.
Problem still there.
Please let me know when you get a chance to look at the file.
Posted: Sat Aug 23, 2014 8:50 pm
by enigmasi
strange_attractor_tracer.abc file is missing
if you could re-upload
Posted: Sat Aug 23, 2014 9:03 pm
by aoktar
attached your revised scene with some hairs. It looks same here. Only different is hair that has not same geometry in LV against PV
Posted: Mon Aug 25, 2014 12:03 am
by mrbrown
Sorry Aoktar, there must have been a misunderstanding.
Here is a scene file with the alembic file included.
My problem is that the splines in the live viewer seems to be effected by the noise in the shader but when i do the render in picture viewer the splines looks flat with one color.
Hope is clear.
Thanks.
