Page 1 of 3
still crashing when opening octane render Dialog
Posted: Wed Aug 13, 2014 4:46 pm
by dive
This is a very simple file that I have attached. There are no lights and only polygons for a simple piece of funiture. Click around, hit ctrl R a few times and then try and open the Octane Dialog. It crashes for me. Please help.
Re: still crashing when opening octane render Dialog
Posted: Wed Aug 13, 2014 5:08 pm
by aoktar
version? bugreport.zip? It doesn't crashes with a simple scene.
Posted: Wed Aug 13, 2014 5:25 pm
by dive
utilizing octane 2.04.1 with stand alone 2.04 or 2.05, i have tried both.
I have 1 quadro k5000 and 3x titan blacks using either driver versions 3.37 and 3.40
bug reports here attached here
Posted: Wed Aug 13, 2014 5:28 pm
by dive
using r15.057
Posted: Wed Aug 13, 2014 5:30 pm
by aoktar
can you render somethings without crashing? i heard quadro+geforce on 340, cannot be stabile. This can be same on 337.
Posted: Wed Aug 13, 2014 5:32 pm
by dive
the furniture will render sometimes but if i load the dialog or itneractive render it crashes almost 100 percent
Posted: Wed Aug 13, 2014 5:36 pm
by aoktar
dive wrote:the furniture will render sometimes but if i load the dialog or itneractive render it crashes almost 100 percent
this is not normal. Can you try to remove quadro and go with others. Also pls try to render something in Standalone to check stability
Posted: Wed Aug 13, 2014 5:39 pm
by dive
Is it really necessary I pull the card out? I don't like opening up my PC. I only use it for view port, not even rendering on it. I can render on it or use it for viewport in standalone perfectly fine.
Posted: Wed Aug 13, 2014 5:51 pm
by aoktar
dive wrote:Is it really necessary I pull the card out? I don't like opening up my PC. I only use it for view port, not even rendering on it. I can render on it or use it for viewport in standalone perfectly fine.
ok, try first to disable quadro for rendering. But i have a friend who has similar setup. After updating to driver 340, he had to remove quadro to work. Feedback of nvidia was that "how could you work together until today?". But i don't wanna be force to do something. But plugin is very stabile with good hardware, doesn't crashes soo much. Many crashes shows that something is wrong on your system or usage.
Posted: Wed Aug 13, 2014 5:57 pm
by dive
I use the same setup in standlone and it works perfectly, quadro enabled or disabled...
Is there a suggest driver to try with the plug in version of octane?
