Page 1 of 3
Auto update won't work (solved)
Posted: Thu Aug 07, 2014 10:50 pm
by Xertyos
Sorry if it's a newbie question, but I've tried browsing the forum and din't find a solution to my problem.
Everything works fine except that - when I'm rendering - the scene doesn't auto update when I move the Daylight infinite (that I've set up to load in the default scene.)
Moving the camera gives the same result: nothing changes.
If I click the "Refresh the Octane scene from Poser" button I can see the changes in position that I've done.
Any help would be highly appreciated.
Thanks in advance.
My specs:
i7-4939 with 32 gigs RAM
GTX 780 - driver v.337.88
Win 7 Pro, 64-bit SP1
Poser Pro 2014 SR 3.1
Octane Standalone 2.04
Poser plugin v. 2.5.3.23
Re: Auto update won't work
Posted: Thu Aug 07, 2014 10:53 pm
by face_off
I suspect you are rendering from a non-Ortho camera - in which case updating of the scene into the Octane viewport does not occur. Pls see http://render.otoy.com/manuals/Poser/?page_id=91 for details. So in summary - switch to the standard camera, and you should be fine. There is also an option in the Settings to allow scaled cameras - mouseover the checkbox for details.
Posted: Thu Aug 07, 2014 10:59 pm
by Xertyos
Wow, Paul. My compliments for the superfast reply! ;)
I'm using the Poser Main camera.
Also, I use Netherworks' Camera Panel Plus 2014 (updated to the latest available version.)
Posted: Thu Aug 07, 2014 11:11 pm
by samhal
Xertyos wrote:Wow, Paul. My compliments for the superfast reply! ;)
I also use Netherworks Camera Panel and it works just fine. However, every now and then the 'daylight' light seems to disconnect from the plugin and the update doesn't happen. Don't know why, but what works for me is to save/reload the scene and everything is back to normal.
Sam
Posted: Thu Aug 07, 2014 11:25 pm
by Xertyos
Sam
Thanks Sam.
To integrate the info, here's something else that I've noticed: when I move the camera, the Daylight checkmark (in the Poser properties tab) toggles off and its icon disappears. It also happens to the Main camera when I frame the scene through the Aux camera.
This makes me think that the issue is due to a Poser issue and that Octane is "innocent."
Posted: Thu Aug 07, 2014 11:33 pm
by samhal
Sam
Thanks Sam.
Hmmm, interesting. I have not seen this before. Not sure what to make of that, but I agree I think is more of a Poser issue. One thing to try is temporarily remove the camera panel and see if the problem clears up.
Posted: Thu Aug 07, 2014 11:37 pm
by Xertyos
samhal wrote: Hmmm, interesting. I have not seen this before. Not sure what to make of that, but I agree I think is more of a Poser issue. One thing to try is temporarily remove the camera panel and see if the problem clears up.
Will try.
Posted: Fri Aug 08, 2014 8:57 am
by Xertyos
OK, I've completely removed Camera Panel and the problem remains.
Posted: Fri Aug 08, 2014 9:09 am
by face_off
Are all the camera scale dials set to 100%?
If you have a simple scene (the default Andy scene) which demonstrates the problem - can you pls post the pz3 file, and I will take a look.
Pau
Posted: Fri Aug 08, 2014 2:47 pm
by Xertyos
face_off wrote:Are all the camera scale dials set to 100%?
Pau
Yeah, the camera dials are set at 100%.
See attached file.
