Menu Items Lost
Posted: Sat Jul 05, 2014 2:19 am
by DrGlassDPM
Greetings,
I'm excited to see the new LW plugin is out, as I can't wait to try it out.
I ended up following the instructions wrong, and did the "Install" instructions, rather than the "Update" instructions in the ReadMe.txt.
*UPDATE INSTRUCTIONS FOR OSX*
Update the plugin is like install it (add the plugin and install the menu bar), but before you must be sure that in your Layout the Octane master plugin is not working to allow reinstall the plugin (open the master plugins panel and remove any Octane plugin master available).
When I realized this, I removed the menu items and the plugin. I then tried to do a fresh install of both but cannot regain the menu items in hierarchal form. What's the best way to get this corrected? Where will they show up if I've done it correctly?
Nick
Re: Menu Items Lost
Posted: Sat Jul 05, 2014 8:32 am
by juanjgon
After install the plugin you need to import the menu branch as you can see in the attached image, clicking with the right button over the main menu root folder.
Re: Menu Items Lost
Posted: Sat Jul 05, 2014 5:10 pm
by DrGlassDPM
Thanks! That did the trick.
