Glossy material, reverse colour pick?
Posted: Thu Jun 19, 2014 5:25 pm
by mdharrington
I seem to remember this before....not sure if it is intentional or accidental.
When picking specular colour on the glossy material....the result is the image reflects the opposite colour in the spectrum....so basically you are picking which colour gets absorbed.
Also the intensity is backwards....picking a darker colour the material shines brighter and vice versa.
This is in version 2 LW
Re: Glossy material, reverse colour pick?
Posted: Fri Jun 20, 2014 7:43 am
by juanjgon
Here it works fine, a glossy node with red specular reflects red light. Can you post an example?
Posted: Sat Jun 21, 2014 1:10 am
by mdharrington
i will as soon as i can....away from the machine right now.
Posted: Sat Jun 21, 2014 8:22 am
by gordonrobb
I get this behaviour when the diffuse is white. Have to say though, I never use a colour for specular. Should I?
Posted: Sat Jun 21, 2014 7:19 pm
by mdharrington
here it is...
scene attached, background removed but the effect is the same
Posted: Sat Jun 21, 2014 7:34 pm
by mdharrington
this is probably something in the render itself....I seem to remember this discussion before....but it is a little weird that the color will reverse depending on the color of diffuse....
I guess in real world black absorbs everything but the color you pick...whereas white would reflect everything except the color you pick...
But this would be very confusing with image maps
Posted: Tue Jun 24, 2014 9:31 pm
by mdharrington
any ideas on this?
is this a bug, or intentional behavior?
Posted: Tue Jun 24, 2014 9:40 pm
by juanjgon
mdharrington wrote:any ideas on this?
It is intentional, because the Standalone also has this behavior. Something related to the physical shading and energy conservation perhaps?
Posted: Wed Jun 25, 2014 2:52 am
by mdharrington
Well I am definitely not qualified to comment on energy conservation....but it seems odd that if your specularity would be close to 1 then the color absorption is reversed?
But maybe that is the way it is....I kinda slept through physics
