Page 1 of 5
				How To : Network Rendering  (GPU DR)
				Posted: Fri Jun 13, 2014 2:40 pm
				by eyeonestudio
				How to Network Rendering ?
(Limited 12 GPU - Including Master Station)
0. Master (C4D, Not Standalone. No Need Standalone)
   Check YOUR IP Address (This is Octane Master IP. Daemon Scan Range)
1. Slave
   Install octane standalone
2. Slave
   Run Command Prompt(Run As Administrator)
   Change Dir  c:\program files\OTOY\OctaneRender 2.00\
   Run Command
octane_slave --net-master-port 21000 --net-master-address Your_IP
   (ex : octane_slave --net-master-port 21000 --net-master-address 192.168.0.24)
   Auto Change Daemon Scan Range 192.168.0.1 ~ 192.168.0.254
3. Master
   Run C4D. Open Live Viewer. Check Menu > Updates > Network Rendering
   ReRun C4D. That's IT...
Thanks...Aoktar(Ahmet), Fooze
				Re: STEP : Network Rendering  (GPU DR)
				Posted: Fri Jun 13, 2014 7:08 pm
				by pxlntwrk
				hi,
thanks for tips...
to easy use you create on ddesktop(or wherever) a shortcut of "octane_slave.exe"
right click on this shortcut >properties> and add in target field :" --net-master-port 21000 --net-master-address 192.168.0.xxx"
(eg:"C:\Program Files\OTOY\OctaneRender 2.00\octane_slave.exe" --net-master-port 21000 --net-master-address 192.168.0.111)
dont loose the space aftre ....\octane_slave.exe"SPACE--net-master-port....
cheers
				Re: How To : Network Rendering  (GPU DR)
				Posted: Fri Jul 04, 2014 11:34 am
				by mate
				The overhead is much worse than expected.
With a 1Gb/s network, so ~100MB/s bandwith, octane only uses about 3MB/s in each direction.
Is this a setting somewhere we missed?
				Posted: Sun Jul 13, 2014 5:57 pm
				by atilak
				Sorry, but there is still need two licenses for standalone, right?. C4d plugin does not work even if you do not insert the license Stand Alone
				Posted: Sat Jul 19, 2014 3:18 am
				by PavilionVL
				Hello! I use Cinema 4D R15 and Octane 2 (2.03 - standalone, 2.01 - for cinema 4d). And I have 2 computers with licenses. I need use Network Render in Cinema 4D via Octane plugin for Cinema 4d.
If I do like you, then I see "Lunching bla-bla-bla...", but if I run "Start Daemon....." so I see my parametrs (port and ect.), but Octane for Cinema 4D don't use 2nd computer (write me: "other version" or "unavailble"),  but I have same version.
Please, Help me!(
				Posted: Tue Jul 29, 2014 6:16 pm
				by Fly
				Any tips on how to do that on a Mac ?
				Posted: Tue Jul 29, 2014 7:04 pm
				by aoktar
				Fly wrote:Any tips on how to do that on a Mac ?
abstrax did some explanation for macos, but I can't check where is that
				Posted: Wed Jul 30, 2014 3:38 pm
				by Fly
				Allright, thanks.
Gonna search for that on the forum.
				Posted: Wed Jul 30, 2014 6:06 pm
				by jblessing
				I got the network rendering working in the standalone app, but inside C4D I only get "Invalid Version" under status. Is it something to do with the C4D plugin only being version 2.03 and the standalone is version 2.04? I don't see any other 2.x versions to download for either one..
				Posted: Wed Jul 30, 2014 6:21 pm
				by aoktar
				jblessing wrote:I got the network rendering working in the standalone app, but inside C4D I only get "Invalid Version" under status. Is it something to do with the C4D plugin only being version 2.03 and the standalone is version 2.04? I don't see any other 2.x versions to download for either one..
why? All links are there everytimes. (2.04)
http://render.otoy.com/forum/viewtopic.php?f=30&t=40462
For netrender setup on macos:
http://render.otoy.com/forum/viewtopic. ... rk#p195020
