Octane for Softimage 1.02 RC8 [Obsolete]
Posted: Wed Jun 11, 2014 10:15 am
by face
This isn´t actual, must rebuild it, please wait...
face
The next update.
Enjoy yourself,
face
FIXED:
  • Animated shader values will work with motion blur.
  • Skip rendered frames will work again. For multiple images, all images must be existing to skip a frame.
ADDED:
  • The use of the SDK 1.55 will support GeForce 7.xx cards. You maybe have to update your current driver to get the plugin working.
  • Distortion parameter added in the ThinLens_Camera shader.
CHANGED:
  • Max samples can now be set to 256000.
DOWNLOAD
MANUAL
INSTALLATION INSTRUCTIONS
  • Please follow the installation instructions in the on-line manual.
NVIDIA DRIVER REQUIREMENTS
  • This version requires video driver 337.xx or higher.
Re: Octane for Softimage 1.02 RC8 [Current]
Posted: Sat Jun 14, 2014 1:30 am
by abeoctane
Hi Face, I tested this version and the Imager node is not working, the tone mapping settings do nothing, please check it out, thank you.
Posted: Sat Jun 14, 2014 5:14 am
by face
abeoctane wrote:Hi Face, I tested this version and the Imager node is not working, the tone mapping settings do nothing, please check it out, thank you.
Set the "Tonemap Type" in the render settings "Misc" group to "Linear". Then the tonemapping from the imager will work.
It´s the same as when you have set a tone mapping in the Imager and try to save an untonemapped exr file in the standalone.
face
Posted: Sat Jun 14, 2014 5:03 pm
by abeoctane
Is working now, thank you very much, :)
Posted: Sat Jun 14, 2014 5:14 pm
by face
abeoctane wrote:Is working now, thank you very much, :)
No problem, the manual is very poor ;)
Haven´t time to update it and develope the plugin.
Will build a new release because this one is missing the fixes from the RC7 and my current state has newer ones than this...
face
