Hi Paul,
Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
Vlad
OctaneRender 2 for Modo [OBSOLETE]
There are more new buttons on the way - so perhaps raise this again in a month once you see the next commands. In the meantime, you can add buttons for these commands yourself.Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
I know Paul, but since this is a 2 release a month, it is not fun loose my configs in octane render, and ui I setup.face_off wrote:There are more new buttons on the way - so perhaps raise this again in a month once you see the next commands. In the meantime, you can add buttons for these commands yourself.Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
You can remember some of your settings between Modo901.CFG deletes with https://docs.otoy.com/Modo/?page_id=1091. It is necessary to delete your Modo*.CFG file in order to pick up some of the new plugin features from time to time.but since this is a 2 release a month, it is not fun loose my configs in octane render, and ui I setup.
The OSX Modo901/10 plugin version installer has been updated due to a problem with the previous installer version.
I have refreshed the STABLE installer downloads at the top of this thread to release 2.25.0.106 (the next TEST build). Pls see the TEST thread for release notes.
