OctaneRender 2 for Poser (Windows/OSX) [OBSOLETE]
Andygraph3D
the quadro 2000 dvi have the last driver as 314.21 version
but you wrote 344 driver version ?!
I found 341.21 on the Nvidia website, which you could try. You may need to say with plugin version 2.12.1.35 until Nvidia release the current driver for your card.
EDIT: There is also a newer beta version at http://www.nvidia.com/download/driverRe ... 1136/en-us.
I have refreshed the STABLE installer downloads at the top of this thread to release 2.16.0.38 (the current TEST build).
Pls see the TEST thread for release notes.
blogfather
Hi Paul!
Sorry I am intruding
My Poser Program cracher when I try to start the combination of the following programs:
Win 7 Pro service pack 1
Poser version 10.0.5.28445 (developer version of the 2014 Pro) (placed in my i-drive)
Octane 16.2 (c drive)
OctaneRender for Poser 2.16.0.38 (64 bit) also with dev. version (C drive)
NVIDIA 344.75 driver (for Rift oculus !!)
Start: The stage is Andy
I also DAZ version, which runs smoothly and insanely fast - not Andy...
My hardware is:
i7 3930K CPU 3.2 GHz
32 GB Ram
Nvidia GTX 690 for rendering
GTX 750 to the monitors - 2 x 27 "
If I try first to load a different .pz3 file I get the following error message - no matter which file I try with:
Trace Back (seneste call last):
   File "C: \ Program Files \ Smith Micro \ Poser Pro 2014 \ Runtime \ Python \ addons \ OctaneRender for Poser \ __ init__.py", line 70, in Render
   File "C: \ Program Files \ Smith Micro \ Poser Pro 2014 \ Runtime \ Python \ addons \ OctaneRender for Poser \ UiManager.py", line 5077, in Show Setup Form
   File "C: \ Program Files \ Smith Micro \ Poser Pro 2014 \ Runtime \ Python \ addons \ OctaneRender for Poser \ Node.py", line 1022 in FillTreeView
   File "C: \ Program Files \ Smith Micro \ Poser Pro 2014 \ Runtime \ Python \ addons \ OctaneRender for Poser \ Node.py", line 1016, in FillTreeView
   File "C: \ Program Files \ Smith Micro \ Poser Pro 2014 \ Runtime \ Python \ addons \ OctaneRender for Poser \ Node.py", line 956, in SetTreeItemText
KeyError: 86
Do you have any suggestions?
best regards
Flemming
Hi Flemming - this could potentially be an installation issue. "KeyError: 86" is the Render Passes node - is it implies that the 2.16 octane.dll has been installed, but not the 2.16 python support files.
Can you pls try the latest TEST (2.21.1.41) build. It will be available in the next 5 mins.
blogfather
The new version 2.21.1.41 gave me this mainWacros:
Now i can start up the Poser software, but when i try to start Octane it gives me this:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 70, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5077, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1022, in FillTreeView
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1016, in FillTreeView
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 956, in SetTreeItemText
KeyError: 90
Hi Flemming. What was the last working version release number that you had installed pls?
blogfather
As mentioned in the first message:
I had assumed that was the version that DIDN'T work. What was the last release that DID work pls?
Also Fleming - can you pls post the full contents of the Octane Log. And also post your octaneplugin.log file (check the top of this forum for it's location).
Return to “Poser”
