1.50 and hdri
Posted: Wed Apr 16, 2014 12:14 pm
by Nubblet
Hi All,
Have only recently come back to rendering after some ongoing health issues and noticed 1.5 release so immediately installed.
First attempt at a render and i have come across a strange effect when plugging a hdri image into the environment. The light seems to be split into sections of varying intensity, as demonstrated in the attached image. While i was off i was still reading these forums and im sure i remember reading/seeing something like this but cant seem to find it. I am assuming it is something simple that i am missing. I have tried changing the projection node but seems to be the same no matter what settings i use.
Re: 1.50 and hdri
Posted: Wed Apr 16, 2014 1:04 pm
by face_off
What version of the plugin are you on? Try the latest 1.52 TEST release to mark sure you are on the latest.
Is your HDRI map a lat/long format? It needs to be - don't use spherical or cubic.
If it's EXR or HDR, set gamma to 1.
Re: 1.50 and hdri
Posted: Wed Apr 16, 2014 2:54 pm
by Zay
Check if "smooth" is enabled on your object.
Re: 1.50 and hdri
Posted: Thu Apr 17, 2014 9:17 am
by Nubblet
I should have thought of that. It was smoothing on the backdrop prop. Disabled by default now?
Re: 1.50 and hdri
Posted: Sat Apr 19, 2014 1:55 am
by face_off
Go into the plugin Setup window, and tick "Smooth Default" to set smoothing on by default. This should be ticked by default.
