OctaneRender for AutoCAD Beta 1.55 [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
I got problems with the latest plugin version 1.55, it seems that it does not save materials, and it shows this message when I open the plugin tab, also it never stops showing the message loading materials. At the end it does not load the saved materials.Please check.
Guillermo, I have seen this error, and thought it was fixed in the 1.55 version of the AutoCAD plugin, but clearly not. I will need to investigate further over the next day or so. In the meantime, I recommend rolling back to the previous version of the plugin.
guillerodriguezv
Hi Paul
I did not mention that I used Save as default option for the materials, hope it helps to solve the problem.
Regards
Guillermo
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
Guillermo - which version of AutoCAD you are running (2013/14/15?) and which plugin release number you are using?
EDIT: I cannot reproduce the problem you are having. I've tried loading Octane 1.5 and earlier scenes, material defaults, and rendertargets, and it is working fine for me. Are you able to give some more info on when this is occurring for you pls? Are you able to provide a scene which always generates the error?
guillerodriguezv
Hi Paul
I am using Autocad 2015 and Octane Plugin version 1.55.08
Regards
Guillermo
TORRES ENFRIAMIENTO-OCTANE.rar
Here is the file
(5.42 MiB) Downloaded 1146 times
Thanks Guillermo. The material CONCRETO has been incompletely saved in that file. I haven't seen them before, however I well amend the plugin so that it pops an error indicating the problem and continues loading.
EDIT: Guillermo - are you updating to Octane 2.0? If so, I will post a new 2.0 version of the plugin with the above fix. If not, I will post a 1.55 version with the fix.
guillerodriguezv
Hi Paul
Maybe in a couple weeks I will update, for the moment I still using 1.55 version of the plugin.
Regards
Guillermo
Hi Guillermo
Unfortunately I have activation issues with my copy of AutoCAD 2015, so haven't been able to test this installer, but if you would like to try it, download from http://render.otoy.com/customerdownload ... _64bit.exe. Release notes are:
1.55.0.9
- Added new color picker
- Improved error handling when loading Octane data from the AutoCAD scene
guillerodriguezv
Working great on AutoCAD 2015.
Guillermo
guillerodriguezv
Hi
Can you make the installer of this plugin version 1.55 for Autocad 2014 please ?
Regards
Guillermo
Of course. http://render.otoy.com/customerdownload ... _64bit.exe.
Return to “Autodesk AutoCAD”
