OctaneRender™ 1.5 for LightWave™ - build 1.50.0
Posted: Tue Mar 25, 2014 6:32 pm
Hello,
This is a new release of the OctaneRender™ for LightWave™ plugin, Version 1.5, build 1.50.0 - released for Lightwave 10.x and 11.x Windows x32 and x64 and for LW 11.x OSX.
This is the final release of the 1.5 plugin version. Thank you to all who gave feedback during the 1.50 development cycle.
Download plugin links:
http://render.otoy.com/customerdownload ... indows.zip
http://render.otoy.com/customerdownload ... .0_OSX.zip
DEMO versions plugin links:
http://render.otoy.com/customerdownload ... s_DEMO.zip
http://render.otoy.com/customerdownload ... X_DEMO.zip
Octane 1.5 new features introduction video:
https://vimeo.com/82954226
How to install the plugin (Windows):
- Download the install file, you can see that inside it there are the plugin for all Lightwave versions, the octane.dll and octane.dat files (for x32 and x64) and a custom LW menu bar file
- Copy the octane.dll and octane.dat files into you install Lightwave/bin directory
- Add the plugin from Lightwave Layout, select the plugin for your Lightwave version (10.x or 11.5 or 11.6)
- Install the custom menu bar to get access to the Octane features
How to update the plugin (Windows):
- It is like install the plugin again (copy the .dll and .dat files to the Lightwave/bin directory and add the plugin and menu bar again), but you must be sure that there aren't any octane master plugins running in the Layout before try to add the plugin again. There is a live master plugin needed to start/stop the engine that must be closed to allow plugin reinstall.
- This build uses the new Octane SDK 1.36, if you are working with Windows please be sure that you update the Octane.dat and Octane.dll files inside your Lightwave/bin folder.
How to install the plugin (OSX):
- Download the install file, you can see that inside it there is the plugin and a custom LW menu bar file
How to update the plugin (OSX):
- It is like install the plugin again (add the plugin and menu bar again), but you must be sure that there aren't any octane master plugins running in the Layout before try to add the plugin again. There is a live master plugin needed to start/stop the engine that must be closed to allow plugin reinstall.
*RELEASE NOTES AND BUGS FIXED*
- In the IPR you have "Save EXR" and "Save EXR tone mapped" in reverse. Fixed.
- Rendering problems with image sequences at 24 fps. Fixed.
- Textures parameters are clamped to 1.0. Fixed.
- Updated documentation.
- Demo version.
Enjoy it
- Demo version.
Enjoy it
