Materials Fail to Save
Posted: Fri Mar 07, 2014 3:49 pm
by Bendbox
Hi Paul,
I'm on version 1.20.1.29 and when I Right click on an Octane material and attempt to save it, I get an error message window that pops up and says, "Failed to Save File". Is this a bug, or am I going about this the wrong way?
Re: Materials Fail to Save
Posted: Fri Mar 07, 2014 8:22 pm
by face_off
Hi
This is a Rhino bug, fixed in SR8.
Posted: Fri Mar 07, 2014 8:40 pm
by eric_clough
Hi Paul ...
When I export a Rhino file (with materials assigned) as an .obj file and open it with Octane SA 1.20 only a couple of materials show up.
They are all there in the Octane plug-in for Rhino so I wonder what's happening in the translation.
It probably does not matter as I will probably not be using the stand alone version ... the plug-in is working very well and seems to be the easiest way for me to get a quick and good rendering.
cheers,
eric
Posted: Fri Mar 07, 2014 11:32 pm
by face_off
Hi Eric - only the material actually used on geometry being rendered in the Octane scene will be exported - so you might have 20 materials in Rhino, but 5 of them are assigned to geometry, so those 5 will get exported to Octane Standalone.
Posted: Fri Mar 07, 2014 11:59 pm
by eric_clough
Hi Paul ..
But if those materials are assigned to layers that the objects are drawn with does this not assign the material to the geometry of the model?
Or is there something I am missing ... do I have to go through an extra step to be sure I have the material attached?
cheers,
eric
Posted: Sat Mar 08, 2014 1:08 am
by face_off
Hi Eric - if you have geometry belonging to a layer, but with the material assigned by "Object", then that object's material will be used (and loaded into Standalone). If the geometry has it's material assigned by "Layer", then that layer's material will be used (and loaded into Standalone). So only materials which are used in the Octane render will be exported to OCS.
Posted: Sat Mar 08, 2014 7:50 am
by eric_clough
I think I understand this, Paul.
But it does not seem to work that way.
I have a file in which there are about 10 layers with materials assigned that are actually used in the model ... though the file must contain nearly 100 materials attached to appropriate layers.
If I render this with Octane for Rhino then all the expected materials show up in the rendering. On the other hand if I export all the parts of the drawing (model) to an .obj file and open this with Stand Alone only one or two of the materials show up as expected.
As I said earlier, this does not really matter to me ... I started learning a little Octane with the stand alone version but am now almost exclusively using the Rhino plug in. But I was curious about this seeming problem.
cheers,
eric
Posted: Sat Mar 08, 2014 8:31 am
by face_off
Eric - to export, you rightclick the Octane Settings tab and select "Export to OCS". That will sav an OCS file with all the material defs and each mesh in an OBJ which will all be automatically linked when you load the OCS in standalone.
Posted: Sat Mar 08, 2014 5:10 pm
by eric_clough
Thanks Paul ...
I will try that today.
eric
