OctaneRender™ for Blender 1.33 - 4.0 beta Win [OBSOLETE]
Posted: Fri Feb 28, 2014 3:59 am
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
Blender Octane Edition - 1.33 - 4.0 beta (2.69) (53.5MB autoinstaller file)
Octane Server - 1.33 - 4.0 beta (7.8MB autoinstaller file)
Happy blending.
- New feature: now "Movable proxies" animation is fully implemented. In the very first draft, so you can test it...
- If you set "Animation mode" to "Full" - all geometry will be reloaded every frame. All meshes will be recalculated every frame, and all transforms will be reloaded, no matter what for type the meshes have. This is the most simple, robust, but slowest animation mode.
- If you set "Animation mode" to "Camera only" - all geometry will be loaded in the first frame of animation, and only camera will be reloaded every frame. This is the fastest "camera fly" animation.
- If you set "Animation mode" to "Movable proxies", you get most flexible animation mode, but most complicated to tune. In this mode, all "Global" and "Scatter" meshes will be loaded only in the first frame, and will not be refreshed in any of subsequent frames. For "Movable proxy" meshes - only transforms of these meshes will be reloaded in every frame. The more "Movable proxy" meshes you have (in comparison to "Reshapable proxy" meshes) - the faster will be the animation. It is usable if the meshes do not change its shape between frames and do not need to be recalculated by Octane. And for "Reshapable proxy" meshes - both transforms and mesh shapes itself will be reloaded every frame (meshes will be recalculated every frame by Octane). It is usable if you have some complicated animated meshes which change its shape between frames, but the more "Reshapable proxy" meshes you have - the slower will be the animation rendering.
Happy blending.
