No Rendertargets Message after installing Poser SR 3.2
Posted: Fri Feb 07, 2014 3:06 am
by cnolte
Hi Paul,
I recently installed SR3.2 for Poser Pro 2012 to fix an issue with my content library not loading (due to IE11 automatic update). But when I go Render-> OctaneRender, I get an error window ("No Rendertarget settings were found for this scene") followed by a mainWacro window containing the following text:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 73, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 4002, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 84, in CreateNodesFromPoserScene
AttributeError: 'Figure' object has no attribute 'SkinType'
I am pretty sure that the error is due to the incorrect Poser Pro 2012 location reference, since I installed my version of Poser at "D:\Poser Pro 2012", but I don't know which (config) file to edit to correct this problem. I did deleted the "OctaneRender for Poser" folder under the Python>addons folder and re-installed Octane (version 1.20.2.1), but this didn't fix the problem.
Christof
Re: No Rendertargets Message after installing Poser SR 3.2
Posted: Fri Feb 07, 2014 3:14 am
by face_off
Hi Christof
The latest TEST release of the plugin (1.29.0.20) resolves this issue - so pls update and your problem should be gone.
