Problem with smoothing
Posted: Wed Jan 29, 2014 1:10 am
by lyyn
I have a big problem of smoothing in a scene, i try to open and close IPR change smoothing parameter, but nothing change, i just use a white octane diffuse chanel in my nodal texture ...
I send you the image with the problem in octane, and without problem in lightwave
thnx a lot
LyyN
Re: Problem with smoothing
Posted: Wed Jan 29, 2014 2:43 am
by Rob49152
I get this sometimes. To get around it I do an octane f9 render and abort it after the first image update. Then when I reopen IPR it's good again.
I don't think the IPR does a good 'loading' of data as the full render does.
Posted: Wed Jan 29, 2014 8:48 am
by juanjgon
Can you please send to me a scene with this problem? ... I don't need the whole object, only a small part where you can see this issue. It doesn't look like a smoothing problem, perhaps it has a problem with normals, or a normal map ... I need to see the scene to know what could be the problem.
Posted: Wed Jan 29, 2014 10:46 am
by lyyn
Hi Juan,
Hi send you the scene with the object in private
Posted: Wed Jan 29, 2014 1:20 pm
by juanjgon
Your problem is the scale of the model. It has near 2 Km. height and Octane has precission problems with the ray tracing algorithms. Fix your issue is easy, you only need to change the "Ray Epsilon" parameter in the kernel from 0.0001 to 0.001
You can also make your model smaller, it is always better work in real units.
BTW, great model !!!
Posted: Wed Jan 29, 2014 1:51 pm
by lyyn
Thank a lot, really good job
it's working
LyyN
