SSS for Leaves?
Posted: Mon Jan 27, 2014 4:30 pm
by Octanius13
Can the subsurface scattering effect be reproduced in Octane on a simple image texture applied on a diffuse material? If not, can it be precisely faked through the use of an opacity map? Are there any other ways to reproduce this effect on flat objects like leaves, white paper etc? Which is the best way to create a realistic foliage etc.>
Re: SSS for Leaves?
Posted: Mon Jan 27, 2014 8:10 pm
by Proupin
That looks gorgeous :_)
Re: SSS for Leaves?
Posted: Mon Jan 27, 2014 10:56 pm
by Karba
Octanius13 wrote:Can the subsurface scattering effect be reproduced in Octane on a simple image texture applied on a diffuse material? If not, can it be precisely faked through the use of an opacity map? Are there any other ways to reproduce this effect on flat objects like leaves, white paper etc? Which is the best way to create a realistic foliage etc.>
Use diffuse transmission
Re: SSS for Leaves?
Posted: Wed Feb 12, 2014 3:36 pm
by Layla_Bressler
Hi Karba
I am trying to use difuse transmission, but it seems to have a problem with the reflection of the leafs in a window when i use it...
When difuse transmission is enable, the reflection of the leaves becomes grey...
Can you help me with that?
Thanks a lot in advance
Layla
Re: SSS for Leaves?
Posted: Wed Feb 12, 2014 3:49 pm
by aoktar
use mix material with a diffuse and a glossy material
Re: SSS for Leaves?
Posted: Wed Feb 12, 2014 4:09 pm
by Layla_Bressler
Sorry Aoktar, but i am not sure how to do that...
Ive tried, but with no results... if i use the difuse transmission on the diffuse material, the reflections are always grey...
I am doing something wrong...
Can you explain how to do that?
Thanks a lot
Layla
Re: SSS for Leaves?
Posted: Wed Feb 12, 2014 4:17 pm
by Layla_Bressler
Here is the problem...
Layla
Re: SSS for Leaves?
Posted: Wed Feb 12, 2014 10:59 pm
by prehabitat
Beautiful work!
Re: SSS for Leaves?
Posted: Thu Feb 13, 2014 12:32 am
by aoktar
i did a sample, i hope can be helpfull.
you need 1.29 or newer standalone to open it
Re: SSS for Leaves?
Posted: Thu Feb 13, 2014 11:51 am
by Layla_Bressler
Thanks a lot Aoktar
Beautiful effect... very nice
I am using the 3dsmax plugin ver 1.2
Ill try to reproduce that today...
Layla
