background-images always stretched
Posted: Mon Jan 27, 2014 2:10 pm
by useruser
hi,
it seems as is something goes wrong with the c4d-backgroundobject no matter which fileformat or resolution i use: the rendered result is always stretched as you can see in the attached screenshot ( R14; latest octane-beta)
thanks in advance
Re: background-images always stretched
Posted: Mon Jan 27, 2014 2:19 pm
by aoktar
hi,
how do you use background?
Posted: Mon Jan 27, 2014 10:38 pm
by useruser
hi,
it is just the standard-background object with an (sometimes animated) texture. normaly i use the backgorundobject for matchmoved/tracking shots. or if i need to adjust a 3D-element into a still image. at the moment i just try to figure out was is possible or not possible with octane concerning compositingstuff in general
btw. would it be possible in the future to enable/disable "show in reflection" for light sources? thank you!
Posted: Mon Jan 27, 2014 10:52 pm
by aoktar
background image will be sized to render output size. if you set lock resolution to specific size it will be match.
enable/disable "show in reflection": is little harder than other visibility option, i'm not sure about future of
Posted: Tue Jan 28, 2014 6:40 am
by bepeg4d
hi,
if you don't want to see the light sources in the riflections, you can set the opacity of the emitters to 0
ciao beppe
Posted: Tue Jan 28, 2014 9:32 am
by useruser
hi aoktar,
this is exactly what not worked in my case: projectresolution is locked in the octane- liverviewer, projectresolution is machting the native resolution of the texture/video/image in the backgroundobject (1080p) but in the octane -liveviewer the backgorund looks always horizontalley stretched as you can see in my screenshot. i ve been using the demofile " backgorund and matte". for this test.
hi bepeg4d,
thank you, the problem is that the light then also has no influence on diffuse anymore if you set the opacitiy to max. but this is what i need very often in productshots.: a couple of lightsources only affecting the diffuse part of an model and nothing else.
Posted: Tue Jan 28, 2014 1:52 pm
by useruser
hi bepeg4d
you are right!
general visibilty drives the amount of reflection while the impact on diffuse parts is not affected. great! sorry, now i got it. so the last thing i miss is to have an include/exclude-function objectlist for lightsources- but maybee this is impossible with unbiased renderer in general.
thank you
Posted: Wed Jan 29, 2014 2:05 pm
by useruser
hi aoktar,
here is a testproject.i think this strechting-issue is a bug or do i something completely wrong? another issue with backgroundobject: is slows the editorspeed a lot. just move with the camera around the cube. its lagging. if you delete the backgroundobject everything is fine.
