Texture maps with transparency
Posted: Thu Jan 16, 2014 2:37 pm
by fibernaut
Hi guys
i want to assign a logo to a model. The logo is a png file with transparency. When i put that into the diffuse channel of my material node the logo area seems to be filled with a black background. In lightwave i often use multiply or add to get a logo or any transparent texture on a model. How can i achieve this in octane? Thanks for any help.
Re: Texture maps with transparency
Posted: Thu Jan 16, 2014 3:50 pm
by FrankPooleFloating
Double-click the Texture Image node you have your image in. Then change to Alpha Image in Node Type.
Posted: Thu Jan 16, 2014 4:02 pm
by fibernaut
It is already set to alpha image. Does octane need a specific file type?
Edit: The main material is plastic (diffuse mat. with turbulence). I only want to add a logo on top of it like with lightwave blending modes.
Posted: Thu Jan 16, 2014 4:39 pm
32bit PNG should work... do you have Alpha Enabled in the LW Image Editor dialog?
Trying to remember how I overlay something without having LW open... I think I use 2 materials and use Material Mixer.. and a 24bit b/w image (opacity map) for the one I want to overlay - and plug into amount... ya, that's da ticket.
Posted: Thu Jan 16, 2014 11:35 pm
by juanjgon
I think that the way to get this effect is to use the image twice, one for apply the color to the object using the texture node as "color image", and other with the texture node set to "alpha" linked to the opacity input.
Posted: Fri Jan 17, 2014 6:47 am
by fibernaut
Thank you both. I'll try that later. For now i have to stick to lw renderer to get the project done. :|
Posted: Sun Jan 26, 2014 10:55 am
by fibernaut
FrankPooleFloating wrote:I think I use 2 materials and use Material Mixer.. and a 24bit b/w image (opacity map) for the one I want to overlay - and plug into amount... ya, that's da ticket.
Thanks FrankPooleFloating. Works fine!
