can't render instances anymore
Posted: Sat Dec 28, 2013 2:55 pm
by giacob
All of a sudden i cant render instancces anymore... proba bly i changed some setting by mistake... but cant figure out wich one... can someone help me?
Re: can't render instances anymore
Posted: Sat Dec 28, 2013 4:24 pm
by juanjgon
You need to be sure that the instanced object and the instancer are enabled in the scene and also you should check the instancing options in the render target root node option panel.
Posted: Sun Dec 29, 2013 12:03 am
by giacob
Thanks but....
1)i suppose that if instances can be rendered in LW vpr they are enabled in scene and can be rendered in IPR. Am i wrong?
2)i have checked all the instances option in the root etc.
So.. whats the matter?
Posted: Sun Dec 29, 2013 12:14 am
by juanjgon
giacob wrote:Thanks but....
Not sure. Can you send to me the scene to check it? ... you can email it to me to [email protected]
Posted: Mon Dec 30, 2013 12:53 pm
by giacob
thanks ... in the end i solved reinstalling the plugin
Posted: Mon Dec 30, 2013 1:26 pm
by UnCommonGrafx
#1 is false: VPR will render instances even if the instanced object is hidden from view.
The version of Octane we have available to us at this time will not render hidden objects' instances.
