Script to create Lua API documentation in html.
Forum for OctaneRender Lua scripting examples, discussion and support.
stratified
ultrafish wrote:This script is crashing with the current demo version of octane because octane[moduleName] == nil when moduleName == 'benchmark' or 'octane'. The crash happens on lines 122 and 164. I was able to put checks in for myself, but I didn't want to post my code since I'm very new to octane and I thought it might be an issue only with the demo version.
Thanks.
I'll update this script as soon as I have some time.
cheers,
Thomas
stratified
I've attached an updated script to the first post. Should work now.
cheers,
Thomas
Wallan
Get an error when trying to run the scriupt.
[string "create-docs.lua"]:136: bad argument #1 to 'functionDoc' (string expected, got function)
Windows 7 Ultimate 64bit 32Gb RAM. Intel Core i7-5820K [email protected] GHZ. Display uses a Gigabyte GTX 460 1Gb VRAM. Octane uses an EVGA GTX 970 4Gb VRAM.
stratified
There are 2 versions of the script attached to the first post (create-docs.lua and create-docs_213.lua). I think you're trying to run create-docs.lua on an OctaneRender version higher than 2.13.
cheers,
Thomas
Wallan
You are so very correct on that one :oops:
Jenish535
It's 2026 already...
Can someone add latest doc in html as the current version is old and so many functions are changed
Jenish535 wrote: Thu Mar 05, 2026 11:17 am It's 2026 already...
OctaneRender documentation is updated and in .htm from some time:
https://docs.otoy.com/standaloneSE/CoverPage.html
And about LUA API, if you run the script in the first page of this discussion in OctaneRender Standalone 2026.2 you get this:
OctaneRender_doc_2026_2.zip
(129.11 KiB) Downloaded 29 times
Happy GPU rendering!
ciao,
Beppe
Return to “Lua Scripting”
