workflow problem
Posted: Tue Sep 28, 2010 6:36 pm
by didierA
I am an architect and works with Revit (Autodesk)
for the rendering, I export to FBX model in 3dmax
all my materials are created with Revit and are mentalray (no choice)
I export from 3dmax octane with the plugin, but unfortunately all my mental ray materials does not follow!
Do you have a solution?
thank you.
Re: workflow problem
Posted: Tue Sep 28, 2010 9:37 pm
by kubo
well, the internal max exporter (the one it's used by octane script) is limited to standard materials only, so prior to using the script or doing a manual export, use any of the free material converters for max out there, there is several and they work almost great, as an example this is the one I use http://www.scriptspot.com/3ds-max/scrip ... yconvertor.
Posted: Wed Sep 29, 2010 9:44 am
by didierA
Thank you for the answer ...
But I'm probably dummy.
I run the script multiconvert,
I set "from mentalray" to "to standardmaterial"
I clik on "save link"
2 files are created "MatLink" and "prolink" :shock:
and here I do not know who to do.
I looked for a reply on the forum scriptspot and on yourtube without succes...
