Layers?
Posted: Thu Dec 05, 2013 3:35 pm
by gold
Is there a way to put objects on layers, and render separate passes?
{ I dont see it in the manual}
thanks
Re: Layers?
Posted: Thu Dec 05, 2013 4:39 pm
by Pandarr
gold wrote:Hi,
thanks
No there is not. You'd have to make the object visible or not in Poser then render that out in Octane for each 'layer'.
Re: Layers?
Posted: Thu Dec 05, 2013 9:45 pm
by face_off
Poser doesn't support any sort of layering system - so you need to manually set the visibility of the items you want rendered/no rendered.
Re: Layers?
Posted: Fri Dec 06, 2013 6:43 pm
by gold
Oh, ok thank you.
Re: Layers?
Posted: Sat Dec 07, 2013 7:29 pm
by Zay
"Advanced Figure Manager 2" has a Layers module that will do exactly that. You simply create the layers you want and name them and then dump props and figures in them. You can then hide those layers and all the stuff you have put in them will be hidden instantly. It's very useful for very big scenes.
http://www.runtimedna.com/Advanced-Figu ... ger-2.html
http://www.runtimedna.com/Advanced-Figu ... ayers.html
Re: Layers?
Posted: Mon Dec 09, 2013 6:54 pm
by gold
Thanks Zay,
Looks good, but I dont see any mention of Octane with that plugin. Do you think you could
control The visibility of Octane objects from there? More important, could you load only a certain
layer into Octane memory, to not overload Octane texture limits, and GPU vram limitations?
Re: Layers?
Posted: Mon Dec 09, 2013 7:55 pm
by Zay
When you hide things in Poser it will not show in octane when you refresh the scene. The tool will just help you organize it in layers.
Try hide stuff in Poser and then refresh the scene in octane to see if it works for you.
Re: Layers?
Posted: Mon Dec 09, 2013 9:05 pm
by face_off
With the plugin release 1.21 (which I am working on right now) you will be able to set the Object Visibility, Camera Visibility and Shadow Visibility for each prop and figure whilst the viewport is open. Not exactly layers - but a step in the right direction.
Re: Layers?
Posted: Tue Dec 10, 2013 2:00 pm
by gold
Sounds very good, Paul.
thank you
