First Try - xFrog Proxy - No Opacity around leaves?
Posted: Tue Dec 03, 2013 10:29 pm
Hi There; I had a go at making a generic mass a proxy object, and selecting an xfrog OBJ file:
The only peculiarity; the proxy tree loaded with a black outline around the leaves (as if the opacity map for the leaf didn't load)
Also tried the same OBJ in MAX and has the same issue (in standard perspective viewport, not Octane). Anyone know what I can do to fix it?
Also had some issues with level - the object was at project elevation 0 - shared level (AHD 30000 iirc), and the object loaded under the toposurface?
I didn't have time to play around with it - family life called. but thought I'd ask here before I waste time if there's a simple fix from you guys?
Andrew
Andrew
