moved images from Octane
Posted: Mon Nov 25, 2013 12:01 pm
by slepy8
Serious problem!!
Never had one before.
After installing 0.99 version I have this issue:
1. I render image in C4D using Octane
2. I render only one element from this image using C4D renderer and ticking "render active objects only"
Images DON'T MATCH..
Before it was all fine! It appears that Octane image has moved.
I'll try to install previous version of renderer.
download these images, and overlap them.
Cameras are protected so it's not the case. It's something wrong with Octane.
Re: moved images from Octane
Posted: Mon Nov 25, 2013 12:10 pm
by aoktar
correct, please check the 0.99 thread
Posted: Mon Nov 25, 2013 12:12 pm
by slepy8
0.96 works fine
Posted: Mon Nov 25, 2013 12:23 pm
by slepy8
what particular in this thread? I don't have time to go through it. I'm working now, and trying to make things done on time!!
Posted: Mon Nov 25, 2013 12:24 pm
by aoktar
slepy8 wrote:what particular in this thread? I don't have time to go through it. I'm working now, and trying to make things done on time!!
fixing now
Posted: Sun Dec 01, 2013 7:29 am
by wiser1973
I have had the same problem when using the object buffer on a mograph cloner or particular object, none of the object buffers match, this is only a octane problem I agree. tried using a Mat ID, but very difficult to use as a nice clean smooth alpha as Mat ID is very jaggered.
Posted: Mon Dec 02, 2013 3:44 pm
by slepy8
Aoktar fixed ths issue - It's all fine now with me, so in your case it must be something else..
Posted: Mon Dec 02, 2013 3:47 pm
by aoktar
wiser1973 wrote:I have had the same problem when using the object buffer on a mograph cloner or particular object, none of the object buffers match, this is only a octane problem I agree. tried using a Mat ID, but very difficult to use as a nice clean smooth alpha as Mat ID is very jaggered.
can you show me something to see the problem?
Posted: Mon Dec 02, 2013 3:59 pm
by aoktar
slepy8 wrote:Aoktar fixed ths issue - It's all fine now with me, so in your case it must be something else..
what about last frame problem?
