Expected Performance?
Posted: Sat Nov 09, 2013 3:18 am
by chris.denovellis
I have been testing out both the Autodesk and regular Windows AMI's.
The streaming performance / latency doesn't seem to be much better than RDP.
Is this expected behavior with the current versions of the AMI's?
Re: Expected Performance?
Posted: Sat Nov 09, 2013 3:51 am
by Goldorak
No, you should be getting 60 fps. What browser/OS are you using, and what is your bandwidth?
Can you provide a screenshot with the status showing your stream fps/rtt etc.?
Posted: Sun Nov 10, 2013 2:01 am
by chris.denovellis
Attached is screen capture.
Running Chrome 30, Windows 8, on an AMD APU.
Firefox is a little better but similar performance.
Posted: Sun Nov 10, 2013 2:02 am
by chris.denovellis
Bandwidth should be ample.
Docsis3 30-50Mb comcast, wired Gig ethernet.
Posted: Mon Nov 11, 2013 11:30 pm
by Goldorak
chris.denovellis wrote:Attached is screen capture.
You're right, bandwidth isn't the issue here, it's the decode time. You are decoding in ~27 ms, so that is limiting you to <40 fps. Typically each free physical CPU core on your system can handle about 720p30 via ORBX.js. What is the CPU config/speed/corecount of your system? Also make sure you don't have any extra tabs running in the background, as those can also eat up CPU cycles if they are running canvas/flash etc.
I am going to work on a simple substitute native launcher URL this week (that works with identical GUID, command line, etc.), and I'd like to have you retest using that in place of the JS client. This way we'll confirm if JS decode speed is what is dropping you below 60 FPS.
Thank you for the feedback. This is very helpful.
Posted: Tue Nov 12, 2013 10:23 am
by SimonG
How do you pull up those figures out of interest
Posted: Sun Nov 24, 2013 3:17 am
by Goldorak
SimonG wrote:How do you pull up those figures out of interest
Based on broad testing of current Gecko/Chromuim browsers on mid range x86 PC's and laptops.
