OcDS WINDOWS 8.1 INSTALLATION ISSUES
Posted: Fri Oct 25, 2013 2:23 am
apparently some changes in windows 8.1 break the packager used for the installer, means it is currently not possible to install the plugin with the installer. to get you running by installing the contents manually, please follow this directions:
- please download this package:
download obsolete
it contains all the contents of the installer. there are folders named after their usual target location, and within them clickable links which open the respective target directory - to copy the stuff in there. - it should finally look like this:
*** note: the daz studio folder might be called differently if you have current betas installed or have used the dzim to install studio; if you have more than one installation of studio running, you need to copy the files into that locations also if you like to use the plugin with them.
C:\Users\YourWinUsername\OctaneRender\Cache\... C:\Users\YourWinUsername\AppData\Roaming\DAZ 3D\OctaneRender_settings.oczdb C:\Program Files\DAZ 3D\DAZStudio4***\msvcp100.dll C:\Program Files\DAZ 3D\DAZStudio4***\msvcr100.dll C:\Program Files\DAZ 3D\DAZStudio4***\octane.dat C:\Program Files\DAZ 3D\DAZStudio4***\octane.dll C:\Program Files\DAZ 3D\DAZStudio4***\OctaneACM.exe C:\Program Files\DAZ 3D\DAZStudio4***\plugins\OctaneRender\plordazs.dll C:\Program Files\DAZ 3D\DAZStudio4***\resources\OctaneRender\... - if you have everything in place, first start the OctaneACM.exe from (any of) the daz studio root folder(s), where you have just copied it, and go through the plugin activation. after that you may start studio, and everything should be up and running...
