Weird Problem + Crash
Posted: Sat Sep 18, 2010 2:57 am
If I link an image to a material channel in the graph editor. Then remove the link. I can no longer access those material parameters in the node inspector. If I reattach the image in the node graph it appears again in the node inspector. If I then change it from the channel input from image/floatimage to something else (like rgbspectrum for example) then the application crashes.I tried it a couple of times and it doesnt always crash.
HOWEVER....
Changing parameters in the node editor and in the graph editor dont update between themselves. So for instance if I attach an image to a diffuse (or any) slot in the graph editor. Then in the node editor change it from image to rgbspectrum (or anything else). The link remains in the graph editor. Then removing the link in the graph editor removes the channel from the node editor! If I then reattach the image to the diffuse (or any) slot in the graph editor the node editor shows the channel again but doesn't update with the new input and still thinks it's what it was before, in this case rgbspectrum.
Steps to reproduce problem...
1) Create a material in the graph editor
2) Add a new image texture in the graph editor
3) Select the material in the graph editor (so you can see the node editor)
4) Attach the image texture to the diffuse channel of the material in the graph editor
5) Disconnect the node you just connected (And watch the diffuse channel disappear from the node editor)
6) Re-attach the image texture to the diffuse slot (Diffuse channel reappears in the node editor)
7) Change the diffuse channel input in the NODE EDITOR to RgbSpectrum (Notice the link to the image texture remains in the graph editor)
8) Detach the image texture from the diffuse channel in the graph editor (Diffuse channel disappears again in the node editor)
9) Reattach the image texture to the diffuse channel in the graph editor (Node editor shows diffuse channel again, but still shows it as RGB Spectrum)
!!!!! What the !!!!!!
It would be nice if you could not only fix this, but also if you make changes in the node editor it will make the relevant graph for you. Makes sense to me...
HOWEVER....
