(Solved) Render problem: Everything is pink
Posted: Mon Oct 07, 2013 7:56 am
by MakeEmSay
Hi All,
I have the following problem: My octane renderer module in C4D will only render in Pink. The scene is still visible from 0-10 samples, but the screen is filled with pink samples when it continues to calculate.
I attached a screenshot to show what it looks like after a couple of samples. It occured after a blue screen, and Octane immediately asked to re-enter my password/account number.
It's not a hardware related problem, since drivers say all is okay and the standalone version and 3D-games run just fine: The rig has two GTX680's.
I tried re-installing C4D, octane standalone, cleaned and re-installed the plugins and rolled back the NVIDIA drivers, but nothing seems to work. Other versions of C4D (R15 instead of R14) didn't bring a solution. Changing the kernel or colour profile in C4D didn't work.
Has anyone of you seen this before, and is there a fix? I couldn't find anything on the forums.
Thanks a lot,
Max
Re: Render problem: Everything is pink
Posted: Mon Oct 07, 2013 9:37 am
by MakeEmSay
Allright, I found the solution.
I tried to re-register the plugin in C4D R14/R15, and after deactivation octane returned back to normal.
It reactivated automatically, so I guessed it double-activated or got confused somehow.
All works awesome now, as it should ;)
