Cuda Erroe and Poser crashing
Posted: Mon Sep 02, 2013 11:31 pm
by bpzen
Hi Paul
Never had this issue before in fact never had octane or poser crash before. Toady I tried to render using my 2 Gig Card (I have 2 cards 2 gig and 4 gig that i use simutanously sometimes) I am getting the followign error then poser exe crashes. I treid both 2012 and 2014 poser same results. I ahev a strange feeling it may be a hardware issu eas teh 4 gig card is workign stand alone fine.
I jsut installed the latest test build and see if it solves stuff.
The script is telling me total mammory req is 1130 meg abotu half the 2 gig cards capabilites
Started logging on 02.09.13 18:39:15
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
-> Failed to launch kernel (pt)
CUDA device 0: Path tracing failed
Re: Cuda Erroe and Poser crashing
Posted: Mon Sep 02, 2013 11:42 pm
by bpzen
Scene
Total Num Texture Maps (rgb) : 35
Total Num Bump/Trans Maps (grayscale) : 34
Total Memory Required for Textures : 1109.3MB (assumes only LDR textures)
Posted: Mon Sep 02, 2013 11:43 pm
by bpzen
updatd driver and octane test build still crashing 4 gig card works fine
Posted: Tue Sep 03, 2013 12:11 am
by face_off
Hi
The cuda error indicates that one of the cards (the 2Gig card) is running out of memory. If you are also using the 2Gig card as your display adapter, then other things will be using up memory. You can switch off Window Aero, etc to save memory, but the easiest solution in this case is to just render with the 4Gig card.
Posted: Tue Sep 03, 2013 12:36 am
by bpzen
yea, strange i use teh 4 gig as my os card, i think something is up with the 2 gig
BTW very nice - create emmiter from curent light! thanks
