Error activating OctaneLive Accont
Posted: Tue Jul 30, 2013 2:48 pm
by Jorgensen
When I try to activate the Octane for Revit plugin I get this error :-/
Does anyone know what can be wrong?
Re: Error activating OctaneLive Accont
Posted: Tue Jul 30, 2013 10:04 pm
by face_off
Let me check with Otoy to see if there is an issue with your license.
I will get back to you...
Posted: Tue Jul 30, 2013 11:38 pm
by FooZe
Hi Jorgensen,
Are you switching machines? Are you making sure to de-activate the plugin license as well as the standalone? Also, you may run into problems when switching machines multiple times in quick succession. The first re-activate will be available within 15-30min, then second will not be available for an hour.
Check in the customer area that the plugin license is also de-activated before re-activation.
Chris.
Posted: Wed Jul 31, 2013 6:30 am
by Jorgensen
Hi Chris
I work on two different machines, and I might had the pluging allready activated on one of them. I will check it and try again.
Thanks.
Posted: Wed Aug 07, 2013 1:32 am
by palhano
Same error message when I try to activate a new license.
I do have another license working with 3dsmax on the same machine.
Any suggestions?
Posted: Wed Aug 07, 2013 3:31 am
by face_off
Any suggestions?
I have escalated this to Fooze. If you install the latest Revit plugin build, it should provide additional details on why the plugin could not be activated.
Posted: Wed Aug 07, 2013 4:26 am
by FooZe
palhano wrote:Same error message when I try to activate a new license.
Any suggestions?
Hi palhano,
Are you talking about a standalone license or Revit plugin?
It doesn't look like you have a Revit plugin license on your account...
Chris.
