Weird Render Queue Issue
Posted: Wed Jul 24, 2013 2:46 am
by Nuge
I am having a weird issue when i render an image in the render queue, it continously re-renders the same image over and over again.
My work flow
1 - Create scene in cimema I can render a single image in the picture viewer, everything works as it should
2 - Save file as a project file and open in the render queue, the file continously renders over and over again, i now get the same result when i render in the picture viewer
Sometimes it works perfectly but 9 times out of 10 i have this issue.
can anyone help its driving me crazy
John
C4D R13 OCTANE 0.72B
Re: Weird Render Queue Issue
Posted: Wed Jul 24, 2013 10:26 am
by pokeit
Hi there,
Are you sure that this isn't the same issue I've had?- Where the camera keyframes are ignored? So in the picture viewer the cam just parks on the first frame of the sequence while merrily rendering all the required frames with no movement?
If so (And I notice you are on R13 like me) do you have scoobycamtools? (Camera plugin) installed?
This sounds suspiciously like what I've been struggling with...
Cheers!
Poke
Posted: Wed Jul 24, 2013 10:32 am
by aoktar
Nuge wrote:I am having a weird issue when i render an image in the render queue, it continously re-renders the same image over and over again.
My work flow
John
can you give me more info to help you? I have no idea at this moment? Is this a camera flytrough animation or other?
i need to see console window output with log output enabled
Posted: Wed Jul 24, 2013 9:14 pm
by Nuge
Hi there,
Cheers!
Poke
Poke
These are still images only, so its not an animation issue i only have 1 frame in the timeline with no key frames!!!
No i dont have scoobycamtools installed
Aoktar,
I will get the logs to you shortly
Hope you can help
Regards John
