beta 72 loose textures again and still washed out colors
Posted: Fri Jul 19, 2013 12:06 pm
by miohn
seems that the new .72 Beta is a little step backwards.
Still have these washed out colors and like in earlier Versions
Octane looses textures.
Haven't been there some improvements in previous version .69 ?
MIke
Re: beta 72 loose textures again and still washed out colors
Posted: Fri Jul 19, 2013 12:17 pm
by pokeit
Do you mean the final render is much brighter/less contrasty than the live viewer? If so that's Linear Workflow. Render your final images in 16bit or convert your project to linear workflow.
I also get some textures that need constant relinking, less than before though. I find it better if you select 'no' when cinema asks you if you want to copy your texture images into the projects' path..
Hope this helps
Cheers!
Poke
Posted: Fri Jul 19, 2013 12:25 pm
by miohn
Hi Poke,
I already discussed that with aoktar.
As soon as I have set texture paths in C4D Prefs,
Cinema won't aks me to make a copy.
Would be nice, if Octane could directly use the
texturepaths from C4D Prefs.
In .69 this was fixed I thought.
Mike
Posted: Fri Jul 19, 2013 12:47 pm
by pokeit
Hi Mike,
I found if I set up the C4D paths it took ages (minutes, in fact it may have crashed never left it long enough to find out) for Octane to export the scene so I gave up :?
Posted: Fri Jul 19, 2013 1:34 pm
by aoktar
this is seems like a wrong settings. Can you check again?
For texture paths: if c4d paths was accesible, we will be using thats.
