Camera issue
Posted: Fri May 31, 2013 8:37 pm
by moontooth
I used [Octane exporter for C4D version 0.12b], It's was working well,
But I do not know why , last week when I export from C4D to Octane,
always got Camera issue the camera looks like very very far away from right position
So for now I can not use Octane for work :cry: :cry: :cry: :cry: :cry: :cry:
Anyone has same problem ?
Waiting for help!
Thanks a lot!
Re: Camera issue
Posted: Fri May 31, 2013 8:44 pm
by bepeg4d
it's surely a scale issue, double check your settings ;)
ciao beppe
Re: Camera issue
Posted: Fri May 31, 2013 8:49 pm
by moontooth
I was try change unit, but nothing help :cry:
Re: Camera issue
Posted: Fri May 31, 2013 9:56 pm
by moontooth
But when I export to Version_1025_beta257_win_x64 with same setting, everything's normal,
NO camera issues,
when use Version 1.0 or 1.1, looks like camera can not Not correctly export.
not just position the resolution has problem too.
Re: Camera issue
Posted: Sat Jun 01, 2013 11:23 pm
by bepeg4d
could you share a simple scene with the camera issue?
ciao beppe
Re: Camera issue
Posted: Sun Jun 02, 2013 2:47 am
by moontooth
here you are.
Re: Camera issue
Posted: Sun Jun 02, 2013 8:07 am
by bepeg4d
no problem here, i have tried with a lot of octane versions with no issue, the c4d scale is in cm and the exporter correctly converted the scale in meters for octane.
if c4d and the exporter should stay the same, the problem must be in the obj import settings in octane, have you something different in this section?
ciao beppe
Re: Camera issue
Posted: Sun Jun 02, 2013 5:22 pm
by moontooth
Sooo strange, I don't know why I follow you step by step still got problem.
I'm thinking maybe some plugin Conflict?
it's just happened on V1.0 and V1.1
and I was try the demo version of octane for C4d, crash anytime then I deleted.
I do not know whether it is for this reason
whatever thanks soooooooooo much for your Patient bepeg4d :D :D :D :D
Re: Camera issue
Posted: Sun Jun 02, 2013 6:40 pm
by bepeg4d
you are welcome, no problem, but is a pity that you can't export from c4d to octane :(
other plugins could give problems during the installation of the integrated plugin but i don't remember of any troubles with the exporter :roll:
i still believe that is related to the scale but i don't know how to help you :(
ciao beppe
Re: Camera issue
Posted: Sun Jun 02, 2013 7:52 pm
by moontooth
Finally, I re install Octane and set everything as yours.
It's work!!!!
Thanks a lot bepeg4d!
yes, I think it's scale problem.
But don't know why in Beta version have no problem.
OctaneRenderâ„¢ for Cinema 4D looks cool!
Maybe should buy one LOL,
then Have too update graphic card ......
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
