Page 1 of 2
OctaneRender® for Poser beta MAC - build 1.14a [TEST]
Posted: Thu May 23, 2013 12:25 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser,
build 1.14a (TEST RELEASE). This version is compiled against Octane 1.14, so see the requirements for that build regarding compatibility with your video card.
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on
Macintosh OS X Snow Leopard, Lion & Mountain Lion.
This Mac version of the plugin is still in development, so this is a beta test version at best, and at the moment has not been sufficiently tested to be a "commercial" quality.
Installation
For the moment, the installer is a ZIP file. Paste the Runtime from the ZIP over the Runtime of the Poser/Poser Pro application. Select "Keep Newer" when pasting.
If you have a support issue,
pls provide the following information:
- Operating System (ie. Mac OS X Mountain Lion)
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
Change Log from release 1.13u
N/A
Differences between the MAC and WINDOWS version
- You cannot rightclick the Progressive save button to open the progressive save folder
- Uses the standard Mac color picker rather than an "advanced" color picker
Known Issues
- IMPORANT: If you close Poser whilst the plugin is open, Poser will crash. So close the plugin prior to shutting down Poser. I am working on a fix for this.
If you have questions....
- Read the manual
- Read the
FAQ
- Watch the
Features Video
- Read the
Features Blog Posting
- Watch the
Introductory Tutorial
- Check the
Facebook Page
- Post your question on this forum thread
Troubleshooting
N/A
Limitations
- Loading a Poser scene by double-clicking a pz3 file in the Windows file explorer, or selecting from your "Recent Files" will not load the previously saved Octane scene data for that file when Poser starts. This is due to a Poser bug which has been reported to Smith Micro. Instead, use the Poser menu File -> Open to open any pz3 files which contain Octane scene data.
[Unconfirmed on the Mac version]
- Material Picking (by clicking on a material in the Poser Material Room) does not select that material in the OctaneRender material tab if you have a camera selected in the Parameter Dials window.
- If you delete a duplicated figure in Poser, when next reloading the scene, the figures may have been renamed, in which case the plugin will not have loaded the materials for the rename figure correctly. This has been reported as a big to Smith Micro and will be fixed.
Download the plugin
HERE
Re: OctaneRender® for Poser beta MAC - build 1.14a [TEST]
Posted: Thu May 23, 2013 5:47 am
by face_off
I just refreshed the installer at the link at the top of this thread with a new version.
1.14a2
- Fixed issue where converting certain skin materials was throwing a python exception
- Fixed a range of issues associated with adding, renaming and deleting scene elements when the plugin is running. In summary, you can add, rename and delete items, and the plugin should not need a refresh (it will do a refresh automatically if the viewport is open).
- Fixed issues with Refresh setting the wrong resolution
Posted: Thu May 23, 2013 1:57 pm
by alaman64
Thanks Paul,
I was able to download and do a quick render before heading off to work. So far works well, the only annoying bug is that i have to activate the plugin every time I go into poser. (it does not save my activation).
I did experience a few random crashes, but not sure if that was poser library or the plugin. I'll do some more testing this evening.
Nick
Posted: Thu May 23, 2013 11:04 pm
by face_off
Thanks Nick
I've fixed some more crashes in the last few hours which should help. If you get Poser crashing to the desktop, have a look at the coredump text file - and post the stack trace.
I'll will fix the activation issue and then post an updated installer. Probably 3-4 hours away.
Posted: Fri May 24, 2013 2:41 am
by alaman64
Hi Paul,
Poser crashed to desktop as soon as i tried to switch from a texture environment. I've pasted a few lines of what it gave me aafter the error, do you want me to past all of it, it seems kind of long...i could email it if that's better.
Nick
Process: Poser Pro 2012 [80509]
Path: /Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/MacOS/Poser Pro 2012
Identifier: com.SmithMicro.PoserPro
Version: 9.0.3.23027 (9.0.3.23027)
Code Type: X86-64 (Native)
Parent Process: launchd [191]
User ID: 503
Date/Time: 2013-05-23 22:30:49.711 -0400
OS Version: Mac OS X 10.8.3 (12D78)
Report Version: 10
Interval Since Last Report: 2384175 sec
Crashes Since Last Report: 283
Per-App Interval Since Last Report: 6592 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: F1DDAC92-3AC6-C92B-35C2-B075142BE351
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000100000000-0000000100dda000 [ 13.9M] r-x/rwx SM=COW /Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/MacOS/Poser Pro 2012
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 ??? 000000000000000000 0 + 0
1 libwx_osx_cocoa-2.9.1.0.0.dylib 0x00000001030c2a36 wxGenericTreeItem::DoCalculateSize(wxGenericTreeCtrl*, wxDC&, bool) + 374
2 libwx_osx_cocoa-2.9.1.0.0.dylib 0x00000001030c358c wxGenericTreeItem::CalculateSize(wxGenericTreeCtrl*) + 76
3 libwx_osx_cocoa-2.9.1.0.0.dylib 0x00000001030c3899 wxGenericTreeCtrl::SetItemText(wxTreeItemId const&, wxString const&) + 137
4 _controls_.so 0x000000011128df58 _wrap_TreeCtrl_SetItemText + 344
5 org.python.python 0x00000001018b981a PyEval_EvalFrameEx + 23498
6 org.python.python 0x00000001018bb8c5 PyEval_EvalCodeEx + 1733
7 org.python.python 0x00000001018b99bf PyEval_EvalFrameEx + 23919
8 org.python.python 0x00000001018ba2a6 PyEval_EvalFrameEx + 26198
9 org.python.python 0x00000001018ba2a6 PyEval_EvalFrameEx + 26198
10 org.python.python 0x00000001018bb8c5 PyEval_EvalCodeEx + 1733
11 org.python.python 0x000000010182eb22 function_call + 178
12 org.python.python 0x00000001017fc162 PyObject_Call + 98
13 org.python.python 0x000000010180e781 instancemethod_call + 401
14 org.python.python 0x00000001017fc162 PyObject_Call + 98
15 org.python.python 0x00000001018b2bd7 PyEval_CallObjectWithKeywords + 87
16 _core_.so 0x000000011084cdf1 wxPyCallback::EventThunker(wxEvent&) + 305
17 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e67e94 wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 84
18 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e68e0f wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 111
19 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e69e1a wxEvtHandler::TryHereOnly(wxEvent&) + 42
20 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e69e8b wxEvtHandler::ProcessEventLocally(wxEvent&) + 59
21 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e69f51 wxEvtHandler::ProcessEvent(wxEvent&) + 161
22 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e69946 wxEvtHandler::SafelyProcessEvent(wxEvent&) + 22
23 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000103060c00 wxWindowBase::HandleWindowEvent(wxEvent&) const + 16
24 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102f6b76c wxWidgetCocoaImpl::DoNotifyFocusEvent(bool, wxWidgetImpl*) + 1308
25 com.apple.CoreFoundation 0x00007fff8dd1beda _CFXNotificationPost + 2554
26 com.apple.Foundation 0x00007fff83dd4e26 -[NSNotificationCenter postNotificationName:object:userInfo:] + 64
27 com.apple.AppKit 0x00007fff845c4db5 -[NSTextField textDidEndEditing:] + 344
28 com.apple.CoreFoundation 0x00007fff8dd1beda _CFXNotificationPost + 2554
29 com.apple.Foundation 0x00007fff83dd4e26 -[NSNotificationCenter postNotificationName:object:userInfo:] + 64
30 com.apple.AppKit 0x00007fff845c4a7a -[NSTextView(NSSharing) resignFirstResponder] + 736
31 com.apple.AppKit 0x00007fff8448e738 -[NSWindow makeFirstResponder:] + 430
32 com.apple.AppKit 0x00007fff844d6b76 -[NSWindow sendEvent:] + 4349
33 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102f58fda wxFromNSPoint(NSView*, CGPoint const&) + 778
34 com.apple.AppKit 0x00007fff844d3674 -[NSApplication sendEvent:] + 5761
35 com.apple.AppKit 0x00007fff843e924a -[NSApplication run] + 636
36 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102f4e803 wxGUIEventLoop::DoRun() + 51
37 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102e38887 wxCFEventLoop::Run() + 55
38 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102d40d28 wxAppConsoleBase::MainLoop() + 72
39 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102ee9bd7 wxApp::OnRun() + 39
40 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000102db6c3d wxEntry(int&, char**) + 141
41 com.SmithMicro.PoserPro 0x0000000100393997 main + 439
42 com.SmithMicro.PoserPro 0x0000000100035738 start + 52
Posted: Fri May 24, 2013 3:00 am
by face_off
Thats perfect Nick - TY.
The import bits are:
which means Poser crashes when the plugin modified the Settings tree control. If I can reproduce these issues, I can attempt to work around them. But the wx.python implementation on the Mac looks questionable.
I have posted a range of changes to the latest version, which you can re-download from the link at the top of this thread. Hopefully one of the changes I have made will resolve the issue where you need to re-activate each time you run the plugin. I am unable to reproduce that error, so I would be interested in your feedback.
1.14a7
- Fixed issue where "floattexture" node changes were not being applied to the Octane scene
- Fixed python exception when Importing a POC file
- Added the ability to edit the Poser to Octane scale factor in the "Config" screen.
- Fixed issue where cuda settings were not being applied
- Fixed issue where "Paste to all materials named ???" raised a python exception
- Fixed issue where "Paste to all skin materials" raised a python exception
- Fixed issues with removing bump maps from the figure and scene
- Fixed permissions error when starting the plugin.
Posted: Fri May 24, 2013 4:14 am
by alaman64
Hi Paul,
Still get the reactivation question, Should I trying to change file permissions manually? if so let me know what directory or file to change.
nick
Posted: Fri May 24, 2013 5:02 am
by face_off
Nick, can you pls confirm that you are running 1.14a7 (the 7 on the end is the important bit). If not, can you pls re-download and try again?
The username/password is stored in /Users/[username]/Library/Preferences/Poser Pro/[9/10]/access.orp, and on your version I suspect it's saving to a file called "9\access.orp". 1.14a7 should fix this issue.
Posted: Fri May 24, 2013 11:12 am
by alaman64
Confirmed, I am running 1.14a7.. still does not save reg. did not find the flle you were talking about. I am running Poser Pro 2012.
this is a dump of my directory.
Posted: Fri May 24, 2013 11:23 am
by face_off
Hi Nick
The access.orp file will be deeper in the folders than that.
For you it should be in /Users/nalamanos/Library/Preferences/Poser Pro/9/access.orp.
The easy way to test is start Poser, then Scripts->Python Shell, and type
os.path.join(poser.PrefsLocation(), "access.orp")
That will tell you where the access.orp password file was saved. If it is not there, there maybe there is a permissions issue with that folder.
