Mesh smoothing, animation geometry updates
Posted: Wed May 22, 2013 6:13 pm
by natedood
Two issues:
1) The mesh smoothing support breaks, especially when animating. I think this may be resolved by simply allowing the user to specify a waiting period before the plug in forces a refresh of the geometry.
2) The geometry does not always update. This results, for example, in a model moving and their hair staying in one place. I think it this could also be fixed with the above option to force a refresh of geometry after each frame.
I've searched and found one reference to the geometry update issue but it included an issue where animation would break after the fourth frame, but I don't believe the geometry issue has been fixed.
I haven't found any mention of the mesh smoothing at all. This is what is used in all the newer daz genesis figures for clothing etc. It fixes poke through, etc.
Re: Mesh smoothing, animation geometry updates
Posted: Wed May 22, 2013 6:52 pm
by t_3
here is some old info for you:
http://render.otoy.com/forum/viewtopic. ... 77#p132377
and here something new:
http://render.otoy.com/forum/viewtopic. ... 57#p140257
regarding animation geometry updates:
please report back if you see this behavior also, if any smoothing modifier is set to "interactive" "on" before starting it, or if it also happens, if there aren't any smoothing modifiers at all; regarding to daz it should be ok to start mesh transfer right after change the frame time - there are commands which will force ds to internally update its geometry, and the plugin won't continue until this is done. so most probably you "only" see another effect of the currently broken smoothing handling...
Posted: Wed May 22, 2013 7:46 pm
by natedood
Ok, I will try those and let you know if it isn't resolved.
Thank you for your quick response time. :)
