RENDER SPEED PROBLEM
Posted: Sat Apr 27, 2013 9:28 am
by awsjolie
Well im having a problem with render speed, the upper image show that.
Sometime the render speed point at 0.0xx samp/s for hours.
I'm using a gtx 690 and have 12gb RAM system.
I'm wondering that what going on? And is it a hardware problem?
May i get some help?
Re: RENDER SPEED PROBLEM
Posted: Sat Apr 27, 2013 10:18 am
by acc24ex
.. is there a chance the GPUs are in SLI mode? - I noticed that on my 590, it wants to default it in SLI mode.. but it didn't affect the render speeds much then.. still check that out..
- which kernel are you using, are both GPUs activated? - and it depends on the scene, interiors with complicated lights are notoriously slow (but I guess not that slow).. test out with a simpler set up maybe
Posted: Sat Apr 27, 2013 11:22 am
by awsjolie
Yes both of gtx690 GPUs is in active with 1 low priority box checked .I'm using PMC for this scene. The point is that with this scene i can get about 2-3M samp/s (i think this is a reasonable speed ) several time although nothing changed in it, but it's just not happend usually. That's why im very confusing now. what's is going on here :? ?
Posted: Sat Apr 27, 2013 4:55 pm
by tonycho
I think something wrong with your gpu setting in your computer
because if normal, the memory for 690 is about 1.8GB but you just 0.6GB
maybe you use other programs that used GPU power?
Posted: Sat Apr 27, 2013 6:48 pm
by awsjolie
tonycho wrote:I think something wrong with your gpu setting in your computer
No...there's just octane was using my GPUs. I started with octane a year ago and haven't seen this problem.
I don't understand much about the memory number. How can i set it right :? ?
Posted: Sat Apr 27, 2013 9:46 pm
by Karba
What is your nvidia multigpu settings? it should be disable.
Posted: Sun Apr 28, 2013 8:10 am
by awsjolie
Wow it works, Karba!!!! Problem was solved by disabling multi-GPU mode.
Thank you everyone :D :D :D !!!!
Posted: Thu May 09, 2013 11:06 am
by awsjolie
Hey Karba, I have a new issue with maybe the same type.
After i disabled my Multi GPU mode, i reach 3-4M samp/s at 800x950 pixels res, it's cool.
Yesterday i tried to render at 3000x3500 pixels res with same scene, nothing changed, and the octane viewport appeared " WARNING! RENDER FAIL! " message although rendering is still processing with ~1.8M Samp/s .
And after that when i back to 800x950 pixels res the " WARNING! RENDER FAIL! " message still exist and my speed drop from 3-4M samp/s to ~1.9M samp/s, mem drop from ~0.8/1.6GB to ~0.8/0.8GB
Any idea ?
Posted: Thu May 09, 2013 8:26 pm
by Karba
awsjolie wrote:Hey Karba, I have a new issue with maybe the same type.
Any idea ?
Look at your memory statistic. You don't have enough memory to render big resolution.
