octane render for 3d max
Posted: Mon Aug 09, 2010 12:48 pm
by Gio91
Hi everyone I am new on this Websit
Does anyone have octane render for 3d max? I couldn't finde anywhere and Can anyone upload it to me?Pease
Re: octane render for 3d max
Posted: Mon Aug 09, 2010 2:21 pm
by radiance
The plugins are not available yet to demo users, only to licensed customers.
We will include them in the next final release demo versions as we still need to align them all and document them,
otherwise our demo forum will be flooded with questions on how to use an undocumented plugin.
Radiance
Posted: Mon Aug 09, 2010 11:35 pm
by ieatfish
Until then, you'll need to export your model as an .obj file and then import it manually into Octane.
Posted: Fri Nov 12, 2010 9:14 pm
by caradi42
Could you explain what setting i should be using along with the state of the scene?
i cant get materials to load from 3ds MAX 2011. I'm exporting as obj with "export materials" Checked
5 object, ground, tire, rim, caliper, Disk. unique names. all collapsed to editable poly. Correct scale.
I've tried standard and MR arch/design materials. all unique also, but i cant get it to import into octane correctly. it comes is with only one place to assign a material and none of the ones in max came over either. best i can do is assign one material to everything and that's it...
so how do i have several materials and how can i get them to import from the OBj?
Posted: Fri Nov 12, 2010 9:48 pm
by Proupin
use standard materials... neither mr nor vray materials will act as separate materials... this is a limitation in the obj exporter btw
