Page 1 of 2
SSS clouds C4D
Posted: Wed Apr 10, 2013 12:18 pm
by mate
Hey there,
I'm trying to replicate this effect
http://render.otoy.com/forum/viewtopic. ... +Generator in the cinema 4D version of octane. It doesn't seem to work, all parameters should be identical. Is there a limitation?
Re: SSS clouds C4D
Posted: Wed Apr 10, 2013 12:23 pm
by mate
To specify: In the standalone, I can plug a texture (eg turbulence) in the Scattering Port of the SSS medium, and if you put the raystepping to a very low value, it comes out as volumetric. in Cinema, when I plug a turbulence (or any other texture) in the scattering port nothing happens.
Re: SSS clouds C4D
Posted: Wed Apr 10, 2013 1:04 pm
by bepeg4d
hi, this is no more possible from octane 1.11, the plugin is build with the new sdk, so is not possible also with c4d, sorry.
ciao beppe
Re: SSS clouds C4D
Posted: Wed Apr 10, 2013 1:36 pm
by aoktar
which version of standalone? Can you show me scenes?
Re: SSS clouds C4D
Posted: Thu Apr 11, 2013 9:12 am
by mate
Standalone version is 1.10
Cinema File is attached.
In a nutshell - turbulence textures in the scattering port and a very low raystep produce a volume-like effect in the standalone. In Cinema it just shows nothing.
Re: SSS clouds C4D
Posted: Thu Apr 11, 2013 9:23 am
by bepeg4d
ok, surely i should be more specific, octane version 1.11 has introduced big changing in the sss field, now is possible to render fog and god rays but , as a side effect, it's no more possible to use volumetric shaders in sss slot:
Improved direct light calculation in SSS materials - as a side effect volumetric noises don't work anymore
as i alredy said, the integrated plugin is build with the 1.11 sdk, so no more volumetric sss but fog
here is the link:
http://render.otoy.com/forum/viewtopic.php?f=33&t=28838
ciao beppe
Re: SSS clouds C4D
Posted: Thu Apr 11, 2013 10:32 am
by mate
Hey Beppe,
Thanks so much for your fast answer! Well, a pity, but fog is nice, too.
Another question: Where do I find the 'fake shadow' option in the Cinema Specular Material?
::mate::
Re: SSS clouds C4D
Posted: Thu Apr 11, 2013 1:24 pm
by aoktar
mate wrote:Hey Beppe,
::mate::
has a tab named fake shadows
Re: SSS clouds C4D
Posted: Fri Apr 12, 2013 7:40 pm
by mate
Hey Aoktar,
Thanks for your answer. Although, in my Cinema 4D, there is no tab 'fake shadows' to be found.
Is it inside of the specular material?
Is it possible that the switch is called 'alpha shadows' - that would be in the render settings - is that the same thing?
::mate::
Re: SSS clouds C4D
Posted: Fri Apr 12, 2013 7:50 pm
by aoktar
mate wrote:Hey Aoktar,
::mate::
Fake shadows is in specular materials. it can be used for speedup calculation and useful for volume fogs or architectural glass.
Alpha shadow is option of kernels. To activate transparency in shadows
